楼主: 沐紫
【活动】庆祝STM32出货量超10亿颗,开发板送不停!
主题
1666
回帖
17
蝴蝶豆
论坛元老
最后登录
2020-12-9
发表于 2016-1-25 10:39:09 | 显示全部楼层
STM32CubeF0软件包 的连接是否有问题,怎么不能下载?
回复 支持 反对
使用道具 举报
1
主题
21
回帖
蝴蝶豆
初级会员
最后登录
2017-10-2
发表于 2016-1-25 10:51:40 | 显示全部楼层
1.使用过Stm32F407和F29和F103zet6
2、Core: ARM 32-bit Cortex™-M4 CPU with FPU,
Adaptive real-time accelerator (ART
Accelerator™) allowing 0-wait state execution
from Flash memory, frequency up to 168 MHz,
memory protection unit, 210 DMIPS
1.25 DMIPS/MHz (Dhrystone 2.1), and DSP
instructions
• Memories
– Up to 1 Mbyte of Flash memory
– Up to 192+4 Kbytes of SRAM including 64-Kbyte of CCM (core coupled memory) data
RAM
– Flexible static memory controller
supporting Compact Flash, SRAM,
PSRAM, NOR and NAND memories
• LCD parallel interface, 8080/6800 modes
• Clock, reset and supply management
– 1.8 V to 3.6 V application supply and I/Os
– POR, PDR, PVD and BOR
– 4-to-26 MHz crystal oscillator
– Internal 16 MHz factory-trimmed RC (1%
accuracy)
– 32 kHz oscillator for RTC with calibration
– Internal 32 kHz RC with calibration
• Low power
– Sleep, Stop and Standby modes
–VBATsupply for RTC, 20×32 bit backup
registers + optional 4 KB backup SRAM
• 3×12-bit, 2.4 MSPS A/D converters: up to 24
channels and 7.2 MSPS intriple interleaved
mode
• 2×12-bit D/A converters
• General-purpose DMA: 16-stream DMA
controller with FIFOs and burst support
• Up to 17 timers: up to twelve 16-bit and two 32-bit timers up to 168 MHz, each with up to 4 IC/OC/PWM or pulse counter and quadrature
(incremental) encoder input
• Debug mode
– Serial wire debug (SWD) & JTAG
interfaces
– Cortex-M4 Embedded Trace Macrocell™
• Up to 140 I/O ports with interrupt capability
– Up to 136 fast I/Os up to 84 MHz
– Up to 138 5 V-tolerant I/Os
• Up to 15 communication interfaces
– Up to 3 × I
2
C interfaces (SMBus/PMBus)
– Up to 4 USARTs/2 UARTs (10.5 Mbit/s, ISO
7816 interface, LIN, IrDA, modem control)
– Up to 3 SPIs (42 Mbits/s), 2 with muxed
full-duplex I
2
S to achieve audio class
accuracy via internal audio PLL or external
clock
– 2 × CAN interfaces (2.0B Active)
– SDIO interface
• Advanced connectivity
– USB 2.0 full-speed device/host/OTG
controller with on-chip PHY
– USB 2.0 high-speed/full-speed
device/host/OTG controller with dedicated
DMA, on-chip full-speed PHY and ULPI
– 10/100 Ethernet MAC with dedicated DMA:
supports IEEE 1588v2 hardware, MII/RMII
• 8- to 14-bit parallel camera interface up to
54 Mbytes/s
• True random number generator
• CRC calculation unit
• 96-bit unique ID
• RTC: subsecond accuracy, hardware calendar
3,做过的项目,控制12通道点击运动,制作GUI界面,跑UCos。在407项目上,RAM空间几乎用完了,需要更高的容量支持。
回复 支持 反对
使用道具 举报
12
主题
415
回帖
蝴蝶豆
高级会员
最后登录
2018-12-6
发表于 2016-1-25 11:35:07 | 显示全部楼层
1、STM32F103C8T6开发板
2、此开发板 采用 103 系列功能最强的芯片 STM32F103C8T6 ,主频 72MHZ,具有 64kB
SRAM,512kBFLASH,1 个 FSMC,1 个 SysTick,2 个 16-bit 增强型定时器,2 个 16-bit
基本定时器,2 个 16-bit 看门狗定时器,3 个 SPI/I2S,2 个 I2C,5 个 USART,1 个 usb
device,1 个 CAN 2.0,3 个 12-bit 的 16 通道的 AD,2 个 12-bit 的 DA,1 个 SDIO。
3、电池充电及电压检测。
STM32F103C8T6
STM32F103C8T6
STM32F103C8T6-数据手册.pdf
1.06 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32F103C8T6-数据手册
回复 支持 反对
使用道具 举报
主题
1
回帖
蝴蝶豆
新手上路
最后登录
2016-1-25
发表于 2016-1-25 15:00:49 | 显示全部楼层
2、   型号为stm32l151c8t6,特点是功耗较低,价格较便宜。
F1升级L1.pdf (312 KB, 下载次数: 0)
回复 支持 反对
使用道具 举报
13
主题
55
回帖
2
蝴蝶豆
高级会员
最后登录
2018-9-3
发表于 2016-1-25 15:18:52 | 显示全部楼层
1. 晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
用过的开发板是STM32F103ZET6开发板
这块板子的可扩展性端口特别强,并且价格便宜。
主要使用过以下型号的芯片:STM32F103C8T6/F107ZE
2.说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料
STM32F103C8T6的特性:
1.内核:arm32位  最高72MHZ
2.存储 128KB的闪存程序存储器 + 20K的SRAM
3.低功耗、超短唤醒时间
4.2个12位ADC
5.7个DMA通道
6.支持定时器、SPI、ADC、I2C、usart等外设
3.基于STM32你做过哪些设计
本人特别熟悉STM32F1系列的产品,主要利用STM32F1系列做过以下项目:
1.CAN总线输出的高精度角度传感器(基于的MLX90316):分辨率能到0.02度
2.掉电多圈磁编码器(基于的ICHAUS旗下IC—PMX芯片):不需要外部供电也能记录转过的圈数
3.物联网通信(利用的是乐鑫公司的ESP8266 wifi soc芯片)
4.大学期间参加过电脑鼠比赛(产品用的STM32F103C8T6做的)
STM32F103C8T6原版数据手册.pdf-EasyDatasheet.pdf
1.11 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
主题
3
回帖
蝴蝶豆
新手上路
最后登录
2017-7-23
发表于 2016-1-25 15:57:41 | 显示全部楼层
1,野火STM32F103开发板,神舟王103开发板,jmdz——STM8开发板
2, STM8S103中文手册.pdf (2.64 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
2
主题
25
回帖
蝴蝶豆
初级会员
最后登录
2019-9-25
发表于 2016-1-25 16:45:30 | 显示全部楼层
一、上图,STM32的开发板有3块,在办公室只有一块原子的STM32F103ZET6开发板,还有两块在家吃灰,分别是STM32F407的和STM32F205的
C:\Documents and Settings\Administrator\桌面\IMG_20160125_162826.jpg
二、1、STM32F103系列我用的比较多,因为外设太丰富,性价比高,很多产品都用这款单片机
--最高72MHz工作频率
--单周期乘法和硬件除法
--从32K到512K字节的闪存程序存储器,这个要看具体型号的啦
--最大64K字节的SRAM
--产生CPU时钟的PLL
--带校准的32KHz的RC振荡器
--睡眠、停机和待机模式
--Vbat为RTC和后备寄存器供电
--2个12位模数转换器,1us转换时间(多达16个输入通道)
--转换范围:0至3.6V
--双采样和保持功能
--温度传感器
DMA
--2个DMA控制器,共12个DMA通道:DMA1有7个通道,DMA2有5个通道
--支持的外设:定时器、ADC、SPI、USB、IIC和UART
--多达112个快速I/O端口(仅Z系列有超过100个引脚)
--26/37/51/80/112个I/O口,所有I/O口一块映像到16个外部中断;几乎所有的端口均可容忍5V信号
--串行单线调试(SWD)和JTAG接口
--多达8个定时器
--3个16位定时器,每个定时器有多达4个用于输入捕获/输出比较/PWM或脉冲计数的通道和增量编码器输入
--1个16位带死区控制和紧急刹车,用于电机控制的PWM高级控制定时器
--2个看门狗定时器(独立的和窗口型的)
--系统时间定时器:24位自减型计数器
--多达9个通信接口:
2个I2C接口(支持SMBus/PMBus)
3个USART接口(支持ISO7816接口,LIN,IrDA接口和调制解调控制)
2个SPI接口(18M位/秒)
CAN接口(2.0B主动)
USB 2.0全速接口
STM32F407用的很少,就用过一次,做家庭总控制器,有168M的频率,1024KB FLASH,192 KB RAM等等,具体不列举,反正很强大,有事没事百度狗狗一下就知道了。
三、做过的产品也不少哦,多功能甲醛检测仪,PM2.5检测仪,喷淋控制器,LED广告牌控制器,智能家庭环保WIFI控制检测系统,还有CAN控制器等等,因为性价比高,选单片机时一般都是毫不犹豫的选STM32F103系列,没办法,谁让你这么强大还这么便宜!
STM32F103xCDE_DS_CH_V5.pdf
2.77 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32F103x8B_DS_CH_V10.pdf
1.82 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32F103x46_DS_CH_V2.pdf
1.52 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
4
主题
51
回帖
蝴蝶豆
金牌会员
最后登录
2019-11-7
发表于 2016-1-25 20:41:51 | 显示全部楼层
STM32F372_STM32F373数据手册—英文.pdf (1.89 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
3
主题
241
回帖
蝴蝶豆
金牌会员
最后登录
2020-10-31
发表于 2016-1-25 20:59:28 | 显示全部楼层
1. 芯片:
2. 特性:
     •    Core: ARM® 32-bit Cortex®-M3 CPU
     –   72 MHz maximum frequency, 1.25 DMIPS/MHz
           (Dhrystone 2.1) performance at 0 wait state memory access
     –   Single-cycle multiplication and hardware division
     •    Memories
     –   256 to 512 Kbytes of Flash memory
     –   up to 64 Kbytes of SRAM
     –   Flexible static memory controller with 4 Chip Select. Supports Compact Flash, SRAM, PSRAM, NOR and NAND memories
     –   LCD parallel interface, 8080/6800 modes
      CD00191185.pdf (3.2 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
10
主题
2210
回帖
8
蝴蝶豆
论坛元老
最后登录
2020-12-9
发表于 2016-1-25 21:07:30 | 显示全部楼层
1、   晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)
STM32F030 应用.pdf (491.61 KB, 下载次数: 0)
回复 支持 反对
使用道具 举报
