楼主: 沐紫
【活动】庆祝STM32出货量超10亿颗,开发板送不停!
主题
94
回帖
蝴蝶豆
高级会员
最后登录
2020-3-24
发表于 2016-1-23 12:21:23 | 显示全部楼层
STM32-F4属于Cortex-M4F构架,这和M0、M3的最大不同就是多了一个F-float,即支持浮点指令集,因此在处理数学运算时能比M0/M3高出数十倍甚至上百倍的性能
使用在继电器保护上!
回复 支持 反对
使用道具 举报
3
主题
17
回帖
蝴蝶豆
新手上路
最后登录
2016-1-23
发表于 2016-1-23 14:19:18 | 显示全部楼层
回复 支持 反对
使用道具 举报
主题
10
回帖
蝴蝶豆
初级会员
最后登录
2018-10-4
发表于 2016-1-23 14:54:09 | 显示全部楼层
STM32F030
Features
Core: ARM® 32-bit Cortex®-M0 CPU,
frequency up to 48
MHz
Memories
– 16 to 256 Kbytes of Flash memory
– 4 to 32 Kbytes of SRAM with HW parity
CRC calculation unit
Reset and power management
– Digital & I/Os supply: VDD = 2.4 V to 3.6 V
– Analog supply: VDDA = VDD to 3.6 V
– Power-on/Power down reset (POR/PDR)
– Low power modes: Sleep, Stop, Standby
Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
Up to 55 fast I/Os
– All mappable on external interrupt vectors
– Up to 55 I/Os with 5V tolerant capability
5-channel DMA controller
One 12-bit, 1.0
μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6 V
– Separate analog supply: 2.4 V to 3.6 V
Calendar RTC with alarm and periodic wakeup
from Stop/Standby
11 timers
– One 16-bit advanced-control timer for
six-channel PWM output
– Up to seven 16-bit timers, with up to four
IC/OC, OCN, usable for IR control
decoding
– Independent and system watchdog timers
– SysTick timer
Communication interfaces
– Up to two I2C interfaces
one supporting Fast Mode Plus
(1 Mbit/s) with 20 mA current sink,
one supporting SMBus/PMBus.
– Up to six USARTs supporting master
synchronous SPI and modem control; one
with auto baud rate detection
– Up to two SPIs (18 Mbit/s) with 4 to 16
programmable bit frames
Serial wire debug (SWD)
All packages ECOPACK®2
DM00088500.pdf (1.63 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
13
主题
55
回帖
2
蝴蝶豆
高级会员
最后登录
2018-9-3
发表于 2016-1-23 15:01:25 | 显示全部楼层
1. 晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
用过的开发板是STM32F103ZET6开发板
这块板子的可扩展性端口特别强,并且价格便宜。
主要使用过以下型号的芯片:STM32F103C8T6/F107ZE
2.说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料
STM32F103C8T6的特性:
1.内核:arm32位  最高72MHZ
2.存储 128KB的闪存程序存储器 + 20K的SRAM
3.低功耗、超短唤醒时间
4.2个12位ADC
5.7个DMA通道
6.支持定时器、SPI、ADC、I2C、usart等外设
3.基于STM32你做过哪些设计
本人特别熟悉STM32F1系列的产品,主要利用STM32F1系列做过以下项目:
1.CAN总线输出的高精度角度传感器(基于的MLX90316):分辨率能到0.02度
2.掉电多圈磁编码器(基于的ICHAUS旗下IC—PMX芯片):不需要外部供电也能记录转过的圈数
3.物联网通信(利用的是乐鑫公司的ESP8266 wifi soc芯片)
4.大学期间参加过电脑鼠比赛(产品用的STM32F103C8T6做的)
STM32F103C8T6原版数据手册.pdf-EasyDatasheet.pdf
1.11 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
35
主题
196
回帖
蝴蝶豆
金牌会员
最后登录
2020-7-2
发表于 2016-1-23 18:00:29 | 显示全部楼层
2、STM32F103RCT6
The STM32F103RC performance line microcontroller incorporates the high-performance ARM® Cortex™-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 256 Kbytes and SRAM up to 48 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. The STM32F103RC offers three 12-bit ADCs, four general-purpose 16- bit timers plus two PWM timers, as well as standard and advanced communication interfaces: up to two I2Cs, three SPIs, two I2Ss, one SDIO, five USARTs, an USB and a CAN.
3、做过两轮平衡车
STM32F103xB数据手册.pdf
1.82 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
6
主题
7
回帖
蝴蝶豆
初级会员
最后登录
2018-9-4
发表于 2016-1-23 21:41:12 | 显示全部楼层
1.晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
使用过STM32F103/107/407系列芯片做项目开发,开发板使用过的有奋斗V5开发板
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)型号为STM32F103VEt6,
stm32F103VET6,arm Cortex-M3内核,512kB Flash, 64KB RAM,最高工作时钟72MHz/90MIPS(1.25DMIPS/MHz),LQFP 100脚封装(片上集成12Bit A/D、D/A、PWM、CAN、USB、SDIO、FSMC等资源)
奋斗STM32开发板V5.2入门手册.pdf (7.35 MB, 下载次数: 0)
STM32F103xC STM32F103xD STM32F103xE 数据手册.pdf
2.77 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
6
主题
77
回帖
蝴蝶豆
高级会员
最后登录
2018-10-20
发表于 2016-1-23 22:38:55 | 显示全部楼层
1、   晒出你使用过的STM32开发板/芯片图片 IMG_20151213_181322.jpg
STM32F469NI
  • 性能:在180 MHz频率下,从Flash执行时,STM32F446和STM32F479能够提供225 DMIPS/608 CoreMark性能,并且利用意法半导体的ART Accelerator™实现了零等待状态。DSP指令和浮点运算单元扩大了产品的应用范围。
  • 图形用户界面:
    • STM32F469和STM32F479集成意法半导体的专利Chrom-ART Accelerator™,在非常低的CPU负载条件下即可实现先进的图形处理功能,并能够提供先进的用户界面和更丰富的体验。
    • 除了集成有TFT-LCD控制器,还集成了新型显示接口(MIPI串行显示接口)。该串行接口通过少量引脚即可连接显示器,并能够提高支持的显示分辨率。
  • 集成:得益于灵活的存储控制器(FMC)和双模式Quad SPI接口,轻松扩展存储范围。在90 MHz下工作的FMC带有一个32位的并行接口,能支持Compact Flash、SRAM、PSRAM、NOR、 NAND以及SDRAM存储器。双模式Quad SPI工作频率为90 MHz,实现了高性价比的NOR Flash,并支持内存映射模式。
  • 音频:2个专用音频PLL,2路全双工I²S和1路串行音频接口(SAI),支持全双工I²S和时分复用(TDM)模式。
  • 通信:
    • 以太网MAC和USB OTG FS及HS,带有专用电源轨使片上USB PHY能够在整个MCU供电电压范围内工作。
    • 扩展通信接口(包括4个USART、4个速度达11.25 Mbit/s的UART、6个速度达45 Mbit/s的SPI、3个具有新型可选数字滤波器功能的I²C、2个CAN、SDIO以及摄像头接口)。
  • 模拟:两个12位DAC和三个速度为2.4 MSPS或7.2 MSPS(交错模式)的12位ADC。
  • 定时器:多达17个频率高达180 MHz的16和32位定时器。
  • 加密:STM32F479还集成了支持AES-128、-192和-256以及三重DES、散列函数(MD5、SHA-1、SHA-2)、HMAC、真随机数发生器(TRNG)的硬件加密加速器。
  • 功效:该系列产品采用意法半导体90 nm工艺和ART Accelerator™,具有动态功耗调节功能,能够在运行模式下和从Flash存储器执行时实现低至280 µA/MHz的电流消耗(@ 180 MHz)停机模式下,功耗为120 µA(典型值)。
资料
STM32F469I-DISCO用户手册
DM00218846.pdf (1.59 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
13
主题
28
回帖
蝴蝶豆
中级会员
最后登录
2018-2-27
发表于 2016-1-24 11:29:52 | 显示全部楼层
这些都是自己的作品
型号是STM32F031K6T6。
DM00109263.pdf(1.9 MB, 下载次数: 2)
DM00118828.pdf(240.64 KB, 下载次数: 1)
DM00141386.pdf(1.48 MB, 下载次数: 1)
Features:
• Core: ARM® 32-bit Cortex®-M0 CPU,
frequency up to 48 MHz
• Memories
– 16 to 32 Kbytes of Flash memory
– 4 Kbytes of SRAM with HW parity
• CRC calculation unit
• Reset and power management
– Digital and I/Os supply: 2.0 to 3.6 V
– Analog supply: VDDA = from VDD to 3.6 V
– Power-on/Power-down reset (POR/PDR)
– Programmable voltage detector (PVD)
– Low power modes: Sleep, Stop and
Standby
– VBAT supply for RTC and backup registers
• Clock management
• Up to 39 fast I/Os
– Up to 26 I/Os with 5 V tolerant capability
• 5-channel DMA controller
• 1 × 12-bit, 1.0 µs ADC (up to 10 channels)
– Conversion range: 0 to 3.6V
– Separate analog supply from 2.4 up to
3.6 V
• Up to 9 timers
– 1 x 16-bit 7-channel advanced-control timer
for 6 channels PWM output, with deadtime
generation and emergency stop
– 1 x 32-bit and 1 x 16-bit timer, with up to 4
IC/OC, usable for IR control decoding
– 1 x 16-bit timer, with 2 IC/OC, 1 OCN,
deadtime generation and emergency stop
– 1 x 16-bit timer, with IC/OC and OCN,
deadtime generation, emergency stop and
modulator gate for IR control
– 1 x 16-bit timer with 1 IC/OC
– SysTick timer: 24-bit downcounter
• Calendar RTC with alarm and periodic wakeup
from Stop/Standby
• Communication interfaces
– 1 x I2C interface, supporting Fast Mode
Plus (1 Mbit/s) with 20 mA current sink,
SMBus/PMBus, and wakeup from Stop
mode
– 1 x USART supporting master synchronous
SPI and modem control, ISO7816
interface, LIN, IrDA capability, auto baud
rate detection and wakeup feature
– 1 x SPI (18 Mbit/s) with 4 to 16
programmable bit frames, with I2S interface
multiplexed
• Serial wire debug (SWD)
• 96-bit unique ID
• Extended temperature range: -40 to +105°C
• All packages ECOPACK®2
3、   基于STM32你做过哪些设计?
回复 支持 反对
使用道具 举报
主题
8
回帖
蝴蝶豆
新手上路
最后登录
2016-1-26
发表于 2016-1-24 11:32:04 | 显示全部楼层
型号是STM32F031K6T6。
Features:
• Memories
Standby
• Clock management
3.6 V
• Up to 9 timers
from Stop/Standby
mode
multiplexed
3、   基于STM32你做过哪些设计?
  心率计量
避障小车
PID电机调速
回复 支持 反对
使用道具 举报
主题
257
回帖
蝴蝶豆
高级会员
最后登录
2017-3-10
发表于 2016-1-24 12:07:25 | 显示全部楼层
1、野火ISO-MINI 芯片是STM32F103VET6
2、CPU     : 32-bit
SRAM    : 64kB
Flash   : 512KB
FSMC    : 1 Flexible Static Memory Controller for SRAM, PSRAM, NOR and NAND Flash,
PLL     : 1 PLL,
RCC     : Embedded Internal RC 8MHz and 32kHz,
RTC     : 1 Real-Time Clock,
NVIC    : 1 Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
TIM     : 4 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
TIM     : 2 16-bit Advanced Timer, 2 16-bit Basic Timer, 2 16-bit Watchdog Timers,
          2 个16位带死区控制和     2 个16位基本定时器        独立型和窗口型
野火迷你开发板
野火迷你开发板
回复 支持 反对
使用道具 举报
