楼主: 沐紫
【活动】庆祝STM32出货量超10亿颗,开发板送不停!
主题
50
回帖
蝴蝶豆
金牌会员
最后登录
2020-9-24
发表于 2016-1-26 09:50:49 | 显示全部楼层
1、   晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)
ows: 2; word-spacing: 0px; -webkit-texFeatures
 Core: ARM® 32-bit Cortex™-M0 CPU,
frequency up to 48 MHz
 Memories
– 16 to 64 Kbytes of Flash memory
– 8 Kbytes of SRAM with HW parity checking
 CRC calculation unit
 Reset and power management
– Voltage range: 2.0 V to 3.6 V
– Power-on/Power down reset (POR/PDR)
– Programmable voltage detector (PVD)
– Low power modes: Sleep, Stop, Standby
– V
BAT supply for RTC and backup registers
 Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
 Up to 55 fast I/Os
– All mappable on external interrupt vectors
– Up to 36 I/Os with 5 V tolerant capability
 5-channel DMA controller
 1 x 12-bit, 1.0 μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6 V
– Separate analog supply from 2.4 up to 3.6
 One 12-bit D/A converter
 Two fast low-power analog comparators with
programmable input and output
 Up to 18 capacitive sensing channels
supporting touchkey, linear and rotary touch
sensors
 Up to 11 timers
– One 16-bit 7-channel advanced-control
timer for 6 channels PWM output, with
deadtime generation and emergency stop
– One 32-bit and one 16-bit timer, with up to
4 IC/OC, usable for IR control decoding
– One 16-bit timer, with 2 IC/OC, 1 OCN,
– Two 16-bit timers, each with IC/OC and
OCN, deadtime generation, emergency
stop and modulator gate for IR control
– One 16-bit timer with 1 IC/OC
– Independent and system watchdog timers
– SysTick timer: 24-bit downcounter
– One 16-bit basic timer to drive the DAC
 Calendar RTC with alarm and periodic wakeup
from Stop/Standby
 Communication interfaces
– Up to 2 I2C interfaces; one supporting Fast
Mode Plus (1 Mbit/s) with 20 mA current
sink, SMBus/PMBus and wakeup from STOP
– Up to two USARTs supporting master
synchronous SPI and modem control; one
with ISO7816 interface, LIN, IrDA
capability, auto baud rate detection and
wakeup feature
– Up to two SPIs (18 Mbit/s) with 4 to 16
programmable bit frame, 1 with I2S
interface multiplexed
 HDMI CEC interface, wakeup on header
reception
 Serial wire debug (SWD)
 96-bit unique ID
 All packages ECOPACK®2
Audio and waveform generation using the DAC in STM32F0xx microcontroller families.pdf (486.25 KB, 下载次数: 0)
回复 支持 反对
使用道具 举报
3
主题
67
回帖
蝴蝶豆
高级会员
最后登录
2020-6-30
发表于 2016-1-26 09:52:47 | 显示全部楼层
1.
2.STM32F051R8T6 内置 64KB 闪存、 8 KB RAM, 采用 LQFP64 封装
a.板载 ST-LINK/V2, 提供模式选择开关, 可把电路板变成一个独立的 STLINK/V2 在线调试器及编程器 ( 通过 SWD 接口烧录和调试代码 )
b.电路板电源: 通过 USB 数据线或外部 5V 电源供电
c.外部应用电源: 3V 和 5V 输出电压
STM32F0-DISCOVERY用户手册.pdf (3.23 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
主题
3
回帖
蝴蝶豆
初级会员
最后登录
2019-11-13
发表于 2016-1-26 10:01:25 | 显示全部楼层
很喜欢 STM的  MCU    自己有空就玩下,淘宝买的血糖仪 里面是 STM8L152   捣鼓了下  弄了个玩具 ,求一套开发板吧。STM32也很想试试
IMG_20160116_210805.jpg IMG_20160121_222333_HDR.jpg IMG_20160121_222417_HDR.jpg IMG_20160121_222317_HDR.jpg IMG_20160121_212412_HDR.jpg
重在参与吧  混个熟脸
回复 支持 反对
使用道具 举报
主题
2
回帖
蝴蝶豆
新手上路
最后登录
2017-3-27
发表于 2016-1-26 10:12:57 | 显示全部楼层
         型号:  STM32F103ZET6
        特性:该芯片具有 64KB SRAM、512KB FLASH、2 个基本定时器、4 个通用定时器、2 个高级定时器、2 个 DMA 控制器(共 12 个通道)、3 个 SPI、2 个 IIC、5 个串口、1 个 USB、1 个 CAN、3 个 12 位 ADC、1 个 12 位 DAC、1 个SDIO 接口、1 个 FSMC 接口以及 112 个通用 IO 口
       STM8 32选型手册.pdf (1.39 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
主题
2
回帖
蝴蝶豆
新手上路
最后登录
2018-5-18
发表于 2016-1-26 10:32:22 | 显示全部楼层
1、
一个是用到的芯片:STM32F207,一个是买了玩的开发板;
2、STM32F207特性:
高达1M字节的Flash存储器, 512字节的动态口令存储器
12个16位和2个32位的定时器,频率可达120MHz,每个定时器有多达4个用于输入捕获/输出比较/PWM或脉冲计数的通道和增量编码器输入
4个USART接口和2个UART接口 (传输速率7.5 Mbit/s,支持ISO7816,LIN,IrDA接口和调制解调控制)
带有专用DMA的10/100 以太网 MAC.,支持硬件IEEE 1588v2(MII/RMII) 8到14bit并行摄像头接口,最高达48Mbyte/s
3、设计:数据采样分析器--采集湿度、温度、pm2.5(通过蓝牙跟pm2.5成品相连)等
stm32f207G.pdf
2.52 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
主题
1
回帖
蝴蝶豆
新手上路
最后登录
2016-1-26
发表于 2016-1-26 10:57:18 | 显示全部楼层
用特定颜色填充目标图像的一部分或全部
将源图像的一部分(或全部)复制到目标图像的一部分(或全部)中
通过像素格式转换将源图像的一部分(或全部)复制到目标图像的一部分(或全部)中
将像素格式不同的两个源图像部分和/ 或全部混合,再将结果复制到颜色格式不同的部分
或整个目标图像中。
用此芯片控制了可调电源
DM00031020_Chap11_16_29_37_zh.pdf
2.13 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
主题
22
回帖
蝴蝶豆
初级会员
最后登录
2019-8-28
发表于 2016-1-26 13:42:18 | 显示全部楼层
1,开发板
特性
1、先说一下103的吧,最早就是玩STM32f103的,这个比较早,最开始用它纯属于因为它资源多,并且中文资料很多,学习起来也方便,上面集成了各种想要的外设。到公司之后,大量接触彩屏,上面集成了FSMC总线,可以直接和RA8875的彩屏驱动芯片对接。以及NANDFLASH和NORFlash等
2、107系列属于互联型,上面有很多的外设接口,多个UART口,以及网络接口,集成USBOTG接口。
3、407和429以及302属于M4的内核,支持硬件浮点运算。主频更是达到180MHz,429集成LCD接口,可以直接驱动LCD。不需要额外的驱动芯片。
项目:
1.空气净化器
2.智能家居控制中心
3.平衡机器人
STM32F10x 内核和基础外设.pdf
4.7 MB, 下载次数: 0, 下载积分: ST金币 -1
回复 支持 反对
使用道具 举报
3
主题
28
回帖
蝴蝶豆
高级会员
最后登录
2018-4-13
发表于 2016-1-26 14:55:21 | 显示全部楼层
stm32f030f4p6
stm32f030f4p6
stm32f030f4p6
stm32f030f4p6真是便宜又大碗,¥3能买到的带串口SPI大内存大flash还要是32位MCU,厉害的没得顶。然后我就从arduino转到stm32了。
特别提一下cubeMX实在是业余爱好者的一大利器。
STM32F030_手册_datasheet.pdf (1.63 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
57
主题
246
回帖
蝴蝶豆
金牌会员
最后登录
2019-7-18
发表于 2016-1-26 15:12:40 | 显示全部楼层
路过支持。
回复 支持 反对
使用道具 举报
1
主题
111
回帖
蝴蝶豆
高级会员
最后登录
2020-9-25
发表于 2016-1-26 15:25:18 | 显示全部楼层
1
金牛开发板
金牛开发板
2 stm32f107有很多UART有双CAN,USBOTG等
stm32f107.pdf (1.87 MB, 下载次数: 0)
回复 支持 反对
使用道具 举报
