H7 HAL库配置的SPI DMA 全双工,读到的数据是0
bjdj0000 提问时间:2018-10-6 15:45 /
   配置如下,读写W25Q128
void MX_SPI1_TxRx_DMA_Init(void)
        MX_GPIO_Init();
          /* Set the SPI parameters */
  SpiHandle.Instance               = SPIx;
SpiHandle.Init.Mode              = SPI_MODE_MASTER;
  SpiHandle.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
  SpiHandle.Init.Direction         = SPI_DIRECTION_2LINES;
  SpiHandle.Init.CLKPhase          = SPI_PHASE_1EDGE;
  SpiHandle.Init.CLKPolarity       = SPI_POLARITY_LOW;
  SpiHandle.Init.DataSize          = SPI_DATASIZE_8BIT;
  SpiHandle.Init.FirstBit          = SPI_FIRSTBIT_MSB;
  SpiHandle.Init.TIMode            = SPI_TIMODE_DISABLE;
  SpiHandle.Init.CRCCalculation    = SPI_CRCCALCULATION_DISABLE;
  SpiHandle.Init.CRCPolynomial     = 7;
  SpiHandle.Init.CRCLength         = SPI_CRC_LENGTH_8BIT;
  SpiHandle.Init.NSS               = SPI_NSS_SOFT;
  SpiHandle.Init.NSSPMode          = SPI_NSS_PULSE_DISABLE;
  SpiHandle.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_ENABLE;  /* Recommanded setting to avoid glitches */
        if(HAL_SPI_Init(&SpiHandle) != HAL_OK)
    /* Initialization Error */
    printf("初始化失败!\n");
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
  /*Configure GPIO pin : PA4 */
  GPIO_InitStruct.Pin = GPIO_PIN_4;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  * @brief SPI MSP Initialization
  *        This function configures the hardware resources used in this example:
  *           - Peripheral's clock enable
  *           - Peripheral's GPIO Configuration
  *           - DMA configuration for transmission request by peripheral
  *           - NVIC configuration for DMA interrupt request enable
  * @param hspi: SPI handle pointer
  * @retval None
void HAL_SPI_MspInit(SPI_HandleTypeDef *hspi)
  if (hspi->Instance == SPIx)
    /*##-1- Enable peripherals and GPIO Clocks #################################*/
    /* Enable GPIO TX/RX clock */
    SPIx_SCK_GPIO_CLK_ENABLE();
    SPIx_MISO_GPIO_CLK_ENABLE();
    SPIx_MOSI_GPIO_CLK_ENABLE();
    /* Enable SPI1 clock */
    SPIx_CLK_ENABLE();
    /* Enable DMA clock */
    DMAx_CLK_ENABLE();
    /*##-2- Configure peripheral GPIO ##########################################*/
    /* SPI SCK GPIO pin configuration  */
    GPIO_InitStruct.Pin       = SPIx_SCK_PIN;
    GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull      = GPIO_PULLDOWN;
    GPIO_InitStruct.Alternate = SPIx_SCK_AF;
    HAL_GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStruct);
    /* SPI MISO GPIO pin configuration  */
    GPIO_InitStruct.Pin = SPIx_MISO_PIN;
    GPIO_InitStruct.Alternate = SPIx_MISO_AF;
    HAL_GPIO_Init(SPIx_MISO_GPIO_PORT, &GPIO_InitStruct);
    /* SPI MOSI GPIO pin configuration  */
    GPIO_InitStruct.Pin = SPIx_MOSI_PIN;
    GPIO_InitStruct.Alternate = SPIx_MOSI_AF;
    HAL_GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStruct);
    /*##-3- Configure the DMA ##################################################*/
    /* Configure the DMA handler for Transmission process */
    hdma_tx.Instance                 = SPIx_TX_DMA_STREAM;
    hdma_tx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
    hdma_tx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
    hdma_tx.Init.MemBurst            = DMA_MBURST_INC4;
    hdma_tx.Init.PeriphBurst         = DMA_PBURST_INC4;
    hdma_tx.Init.Request             = SPIx_TX_DMA_REQUEST;
    hdma_tx.Init.Direction           = DMA_MEMORY_TO_PERIPH;
    hdma_tx.Init.PeriphInc           = DMA_PINC_DISABLE;
    hdma_tx.Init.MemInc              = DMA_MINC_ENABLE;
    hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
    hdma_tx.Init.Mode                = DMA_NORMAL;
    hdma_tx.Init.Priority            = DMA_PRIORITY_VERY_HIGH;
    HAL_DMA_Init(&hdma_tx);
    /* Associate the initialized DMA handle to the the SPI handle */
    __HAL_LINKDMA(hspi, hdmatx, hdma_tx);
    hdma_rx.Instance                 = SPIx_RX_DMA_STREAM;
    hdma_rx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
    hdma_rx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
    hdma_rx.Init.MemBurst            = DMA_MBURST_INC4;
    hdma_rx.Init.PeriphBurst         = DMA_PBURST_INC4;
    hdma_rx.Init.Request             = SPIx_RX_DMA_REQUEST;
    hdma_rx.Init.Direction           = DMA_PERIPH_TO_MEMORY;
    hdma_rx.Init.PeriphInc           = DMA_PINC_DISABLE;
    hdma_rx.Init.MemInc              = DMA_MINC_ENABLE;
    hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_rx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
    hdma_rx.Init.Mode                = DMA_NORMAL;
    hdma_rx.Init.Priority            = DMA_PRIORITY_VERY_HIGH;
    HAL_DMA_Init(&hdma_rx);
    __HAL_LINKDMA(hspi, hdmarx, hdma_rx);
    /*##-4- Configure the NVIC for DMA #########################################*/
    /* NVIC configuration for DMA transfer complete interrupt (SPI1_TX) */
    HAL_NVIC_SetPriority(SPIx_DMA_TX_IRQn, 1, 1);
    HAL_NVIC_EnableIRQ(SPIx_DMA_TX_IRQn);
    /* NVIC configuration for DMA transfer complete interrupt (SPI1_RX) */
    HAL_NVIC_SetPriority(SPIx_DMA_RX_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(SPIx_DMA_RX_IRQn);
    /*##-5- Configure the NVIC for SPI #########################################*/
    /* NVIC configuration for SPI transfer complete interrupt (SPI1) */
    HAL_NVIC_SetPriority(SPIx_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(SPIx_IRQn);
收藏 评论6 发布时间:2018-10-6 15:45
6个回答
butterflyspring 回答时间:2018-10-17 17:24:08
有用过示波器看过SPI?
oujisang 回答时间:2018-10-19 11:24:13
先不要用DMA方式,先用查询方式确定你的硬件电路和你的程序没有问题,然后在改用DMA方式提升效率!
STMCU + 2
bjdj0000 回答时间:2018-10-19 20:50:42
oujisang 发表于 2018-10-19 11:24
先不要用DMA方式,先用查询方式确定你的硬件电路和你的程序没有问题,然后在改用DMA方式提升效率! ...
不用DMA读写都正常的,没问题,就DMA解决不了,也没有示波器!就看看那个大神解决了
bjdj0000 回答时间:2018-10-19 20:51:02
butterflyspring 发表于 2018-10-17 17:24
有用过示波器看过SPI?
没示波器,但是不用DMA读写SPI正常
oujisang 回答时间:2018-11-22 10:11:40
你是否开启了CPU的cach功能,如果开启了就关闭掉,就可以了!
chuanlinrong 回答时间:2019-8-16 18:45:05
楼主最后解决了吗?我现在也是这个问题。轮询模式是正常的,读写都可以。但是改成DMA之后,发现DMA 发送和 接收中断都可以进,但是最后数据都是0.。头大啊
