通过电压反馈AD输入从而调节PWM波的占空比
701223poi 提问时间:2017-7-24 10:44 /
为恒流源提供PWM的输入,通过分压采进来一个2.5V左右的电压,根据与2.5V的差值经过简单的计算来调节一个50KHz的PWM波形的占空比,应该是个挺简单的程序,但是我出来的效果并不好
效果大致就是,出来一段PWM波,然后出现一段时间的持续高电平,然后继续输出PWM波,也不知道是什么原因导致的,是因为PWM和我的AD部分存在冲突么?
下面是程序:
#include <stdio.h>
#include "stm32f10x.h"
void Delay(void)
        int x,y;
        for(x=100;x>0;x--)
                for(y=1000;y>0;y--);
void Init_TIMER(void)
        TIM_TimeBaseInitTypeDef         TIM_BaseInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
        TIM_DeInit(TIM4);
        TIM_InternalClockConfig(TIM4);
        TIM_BaseInitStructure.TIM_Period = 1440-1;
        TIM_BaseInitStructure.TIM_Prescaler = 0;
        TIM_BaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM4, &TIM_BaseInitStructure);
        TIM_ARRPreloadConfig(TIM4, ENABLE);
        TIM_Cmd(TIM4, ENABLE);
void Init_PWM(uint16_t Dutyfactor)
          TIM_OCInitTypeDef  TIM_OCInitStructure;
          TIM_OCStructInit(&TIM_OCInitStructure);
          TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
          TIM_OCInitStructure.TIM_Pulse = Dutyfactor;
          TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
          TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OC3Init(TIM4, &TIM_OCInitStructure);
          TIM_OC3PreloadConfig(TIM4,TIM_OCPreload_Enable);
    TIM_CtrlPWMOutputs(TIM4,ENABLE);
void PWM_GPIO_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
void key_Configuration(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD ,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
void ADC_Configuration(void)
        ADC_InitTypeDef ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO | RCC_APB2Periph_ADC1,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfChannel = 1;
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
        ADC_Cmd(ADC1, ENABLE);
        ADC_ResetCalibration(ADC1);
        while(ADC_GetResetCalibrationStatus(ADC1));
        ADC_StartCalibration(ADC1);
        while(ADC_GetCalibrationStatus(ADC1));
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
int main(void)
        u16 Temp_Value;
        u16        cha_0;
        u16 cha_1;
        uint16_t Pulse=749;
        PWM_GPIO_Init();
        key_Configuration();
        ADC_Configuration();
        Init_TIMER();
        Init_PWM(Pulse);
while(1)
        if(GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_11)==0)
                        while(1)
                                Temp_Value = ADC_GetConversionValue(ADC1);
                                if(Temp_Value>=3102)
                                        cha_0=(int)((Temp_Value-3102)/74.5);
                                        Pulse=(int)(Pulse+(cha_0*14.4));
                                        TIM_SetCompare3(TIM4,Pulse);
                                if(Temp_Value<=3102)
                                        cha_1=(int)((3102-Temp_Value)/74.5);
                                        Pulse=(int)(Pulse-(cha_1*14.4));
int fputc(int ch, FILE *f)
  USART_SendData(USART1, (uint8_t) ch);
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
  return ch;
收藏 评论8 发布时间:2017-7-24 10:44
8个回答
dapan100 回答时间:2017-7-25 08:56:03
1.你的ADC时钟没分频,不知道有没有超出ADC最大频率
2.改写占空比太频繁了,定时器打开预加载。你都不等ADC转换完成一直在读有什么意义呢?
要我做会把AD采集和PWM输出同步起来,另外设个控制频率
参与人数 2ST金币 +4 收起 理由
MrJiu + 2 很给力!
LB_yjy 回答时间:2017-7-25 09:06:37
2.改写占空比太频繁了,定时器打开预加载。你都不等ADC ...
强!
701223poi 回答时间:2017-7-25 12:04:12
我用的是STM32F107它的AD部分时钟和103增强型相同,用的是默认时钟配置,默认应该是APB2是72Mhz,在ADC那里是2分频,我查的是给56Mhz时钟时速度最快,但是我不太清楚这个56M是怎么设置得到的,程序里用的采样时间是55.5cycles。
AD采集和PWM同步应该怎么做呢?是用DMA中断么?
控制频率应该怎么设置呢?
dapan100 回答时间:2017-7-25 13:33:44
701223poi 发表于 2017-7-25 12:04
我用的是STM32F107它的AD部分时钟和103增强型相同,用的是默认时钟配置,默认应该是APB2是72Mhz,在ADC那 ...
ADC最大时钟14M,分频系数分别为2468(复位值是二分频,也就是你AD超频了。转换值还准不准没试过)
应该调用一下RCC_ADCCLKConfig(RCC_PCLK2_Div6),给ADC的时钟变为12M。
同步就用定时器触发,控制频率也是用定时器实现
701223poi 回答时间:2017-7-25 14:17:44
应该 ...
● ADC转换时间:
─  STM32F103xx增强型产品:时钟为56MHz时为1μs(时钟为72MHz为1.17μs)
─  STM32F101xx基本型产品:时钟为28MHz时为1μs(时钟为36MHz为1.55μs)
─  STM32F102xxUSB型产品:时钟为48MHz时为1.2μs
─  STM32F105xx和STM32F107xx产品:时钟为56MHz时为1μs(时钟为72MHz为1.17μs)
这是在手册上看到的,这个应该是APB2给它的时钟,但是不太清楚56Mhz是怎么得到的,
dapan100 回答时间:2017-7-25 15:39:22
701223poi 发表于 2017-7-25 14:17
● ADC转换时间:
─  STM32F10 ...
8M9倍频是72M,7倍频不就是56M了。。。ADC转换一次最少需要1.5+12.5个周期,最大时钟14M,所以是1uS。因为56M4分频刚好是14M,而72M要6分频是12M,所以56M时是1uS,72M反而是1.17uS了
701223poi 回答时间:2017-7-25 15:51:51
dapan100 发表于 2017-7-25 15:39
8M9倍频是72M,7倍频不就是56M了。。。ADC转换一次最少需要1.5+12.5个周期,最大时钟14M,所以是1uS。因 ...
大致明白了,我来试试,
谢谢啦
手动:滑稽
701223poi 回答时间:2017-7-27 17:48:01
修改了之后似乎还是不行,,
依然是和以前差不多的,还是一小段PWM波然后接一长段的持续高电平输出
