stm8 硬件IIC 双机通信 求解 谢谢
johnhechang 提问时间:2014-9-9 20:56 /
我想实现stm8  硬件IIC  双机通信  主机已经测试过可以读写24C02,但是改为双机通信时(主机主模式写从机从模式读) ,从机用中断,无法实现。ST-LINK仿真发现主机停在while(!(I2C_SR1&0x02)); 从机没有进入中断 ,请牛人看看是什么问题,非常感谢。
主机程序
 #include"stm8s103f3p.h"
void CLK_Init(void)  //时钟为16M
        CLK_CKDIVR = 0x00;
void IIC_Init(void)//IIC初始化设置 100KHZ
        I2C_CR1    = 0x00; //禁止I2C外设
        I2C_FREQR = 0x0a;
        I2C_CCRH = 0x00;
        I2C_CCRL = 0x32;
        I2C_TRISER = 0x04;
        I2C_CR2 |=0x04;
        I2C_CR1 |=0x01
void IW_24C02(unsigned char x)  //IIC主模式写一个字节
        unsigned char temp;
        //I2C_CR2 &=~ 0x04;
        while(I2C_SR3 & 0x02); //总线空闲
        I2C_CR2 |= 0x01; //产生起始位
        while(!(I2C_SR1 & 0x01)); //起始位发送完成
        I2C_DR = 0xa0;
        temp = I2C_SR1;
        temp = I2C_SR3;
        I2C_DR = 0x00;
        while(!(I2C_SR1 & 0x84));
        I2C_DR = x;
        I2C_CR2 |= 0x02;
//        I2C_CR2 |= 0x04;
void delay (unsigned int x)//延时
        unsigned int i;
        for(i=x;i>0;i--);
main()
        unsigned char dirflag,k,h,u;
        CLK_Init();
        GPIO_Init();
        IIC_Init();
        while(1)
                IW_24C02(3);
          delay(200000);//延时很重要
以上 主机可以读写24C02
从机 程序如下;
        CLK_CKDIVR = 0x00;
        I2C_FREQR = 0x0a;
        I2C_CCRL = 0x32;
        I2C_CCRH = 0x00;
        I2C_TRISER = 0x04;
        I2C_OARL   = 0xa0;                  //自身地址
        I2C_OARH   = 0x40;
        I2C_CR2 |=0x04;
        I2C_CR1 |=0x01;
        I2C_ITR=0x06;//开IIC中断
        unsigned int i;
        for(i=x;i>0;i--);
main()
        _asm("sim");
        CLK_Init();
        GPIO_Init();
        IIC_Init();
        _asm("rim");
  while(1)
@far @interrupt void iic_irq(void)
                while(!(I2C_SR1 & 0x02));
                temp1 = I2C_SR1;
                temp2 = I2C_SR3;
                temp= I2C_DR ;
                 I2C_CR2 |= 0x02;
                //dispp();
仿真一直没有进入中断,
下面是stm8_interrupt_vector的修改;
/*        BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
 *        Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
extern void _stext();     /* startup routine */
@far @interrupt void iic_irq(void);
struct interrupt_vector const _vectab[] = {
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, NonHandledInterrupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, iic_irq}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
不只是哪里有问题 ,请牛人指导,谢谢  本人刚用STM8。
收藏 1 评论10 发布时间:2014-9-9 20:56
10个回答
johnhechang 回答时间:2014-9-9 21:09:40
RE:stm8 硬件IIC 双机通信 求解 谢谢
求助 ,刚刚加的论坛 ,不熟悉 请谅解。
zh384407950 回答时间:2014-9-10 19:37:37
cccccccccccccccccccccc
百年干啤 回答时间:2014-9-13 09:38:06
回复:stm8 硬件IIC 双机通信 求解 谢谢
kkkkkkkkkkkkkkkkkkkkkkkkkkk
aibaibai 回答时间:2016-2-2 09:17:53
楼主你的问题解决了吗
zcl201207 回答时间:2016-2-2 22:18:23
dream_one 回答时间:2016-11-23 11:39:00
是不是系统时钟不同啊?
peter001 回答时间:2016-11-24 00:28:19
关注一下
STM32F051 回答时间:2016-12-14 00:15:16
STM8双机通讯,失败的可能性极大;我几年前不得不改成模拟IIC端口,就是按IIC的时序,不停写IO端口;听说后续的STM32F0系列,已经重新设计了IIC核;新的核怎么样,我还没测试过;心里有些怕。所以,上来看看
ts2000 回答时间:2016-12-17 09:31:40
模拟的比硬件的好用。。。。。。
12下一页
