查看: 3588|回复: 1
STM32 PWM输出问题
主题
4
回帖
蝴蝶豆
新手上路
最后登录
2019-4-24
发表于 2012-12-26 12:54:25 | 显示全部楼层 |阅读模式
目前用stm32做BLDC驱动,PWM输出碰到问题
1、初始化GPIO口复用为TIM 输出脚后,默认即为高电平输出(实际有效电平为高电平)
2、在PWM输出过程中,关闭某一路通道输出,发现该通道与对应互补通道均输出高电平,应为低电平才对
也尝试改过PWM的输出模式及输出极性,没有效果。还是贴下源码吧
void TIM8_PWM_Config(void)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
   /* TIM8 clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
    /* Time Base configuration */
    // ARR = TIM8CLK / ChopperFreq  ChopperFreq:16KHz
    TIM_TimeBaseStructure.TIM_Prescaler = 0;    //预分频 PSC
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_Period = PWM_PERIOD - 1;    //PWM周期TIM_ARR寄存器
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                    //TIM输出通道初始化
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = CH1_PULSE;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
    TIM_OC1Init(TIM8, &TIM_OCInitStructure);
    TIM_OCInitStructure.TIM_Pulse = CH2_PULSE;
    TIM_OC2Init(TIM8, &TIM_OCInitStructure);
    TIM_OCInitStructure.TIM_Pulse = CH3_PULSE;
    TIM_OC3Init(TIM8, &TIM_OCInitStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                    //TIM输出通道4初始化,用来触发AD注入采样
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
    TIM_OC4Init(TIM8,&TIM_OCInitStructure);
  /* Automatic Output enable, Break, dead time and lock configuration*/
    TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; //死区刹车初始化
    TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
    TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
    TIM_BDTRInitStructure.TIM_DeadTime = 12;
    TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
    TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;//TIM_BreakPolarity_Low;
    TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;//TIM_AutomaticOutput_Disable;
    TIM_BDTRConfig(TIM8, &TIM_BDTRInitStructure);
     TIM_OC1PreloadConfig(TIM8,TIM_OCPreload_Enable);      //使能捕获比较寄存器预装载(通道1)
    TIM_OC2PreloadConfig(TIM8,TIM_OCPreload_Enable);          //使能捕获比较寄存器预装载(通道2)
    TIM_OC3PreloadConfig(TIM8,TIM_OCPreload_Enable);          //使能捕获比较寄存器预装载(通道3)
    //TIM_ITConfig(TIM8, TIM_IT_COM, ENABLE);   //使能COM事件中断
    TIM_SelectInputTrigger(TIM8, TIM_TS_ITR2);  //输入触发源选择TIM4
    /* TIM8 counter enable */
    TIM_Cmd(TIM8, ENABLE);
    /* Main Output Enable */
    TIM_CtrlPWMOutputs(TIM8, ENABLE);
void TIM8_GPIO_Config(void)
    /* GPIOA and GPIOB clocks enable */
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC, ENABLE);
  /* GPIOC Configuration: Channel 1, 2 and 3 as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* GPIOE Configuration: Channel 1N as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;   //BKIN
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  /* GPIOB Configuration:2N and 3N as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14 | GPIO_Pin_15;
  /* Connect TIM pins to AF */
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_TIM8);     //UH
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_TIM8);    //VH
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM8);    //WH
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_TIM8);    //UL
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_TIM8);    //VL
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_TIM8);    //WL
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_TIM8);    //BKIN
  /* Enable the TIM8 Trigger and commutation interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = TIM8_TRG_COM_TIM14_IRQn;
void MC2_Commutation(uint8_t dir, uint8_t tab)
    switch(tab)
        case 5:     //BA(1L,2H)
            /*  Channel1 configuration */
            TIM_SelectOCxM(TIM8, TIM_Channel_1, TIM_OCMode_Active);
            TIM_CCxCmd(TIM8, TIM_Channel_1, TIM_CCx_Disable);
            TIM_CCxNCmd(TIM8, TIM_Channel_1, TIM_CCxN_Enable);
            /*  Channel2 configuration */
            TIM_SelectOCxM(TIM8, TIM_Channel_2, TIM_OCMode_PWM1);
            TIM_CCxCmd(TIM8, TIM_Channel_2, TIM_CCx_Enable);
            TIM_CCxNCmd(TIM8, TIM_Channel_2, TIM_CCxN_Disable);
            /*  Channel3 configuration */
            TIM_CCxCmd(TIM8, TIM_Channel_3, TIM_CCx_Disable);
            TIM_CCxNCmd(TIM8, TIM_Channel_3, TIM_CCxN_Disable);
            break;
      case 4:
        default:
            break;
使用道具 举报
2
主题
15
回帖
蝴蝶豆
中级会员
最后登录
2020-11-2
发表于 2013-10-9 18:36:21 | 显示全部楼层
回复:STM32 PWM输出问题
你这个编译通不过吧!
 RCC_APB2PeriphClockCmd(   RCC_APB2Periph_AFIO
       | RCC_APB2Periph_GPIOA
       | RCC_APB2Periph_GPIOB
       | RCC_APB2Periph_GPIOC
       | RCC_APB2Periph_GPIOD , ENABLE );
回复 支持 反对
使用道具 举报
