LL 库现在BUG太多希望官方能重视LL库
lqs0905 发布时间:2018-11-30 11:58
收藏 评论14 发布时间:2018-11-30 11:58
14个回答
lqs0905 回答时间:2018-11-30 15:20:41
1.就当我哔众取宠吧
2.希望我的发现对一些人有用
3.希望STM 的LL库越来越好用
4.无意冒犯请原谅
deyagu 回答时间:2018-11-30 16:05:45
你看的是例程吧!再说了你看了程序运行时寄存器值吗?LL库也确实有很多不完整的地方
MrJiu 回答时间:2018-11-30 16:17:16
lqs0905 发表于 2018-11-30 15:20
1.就当我哔众取宠吧
2.希望我的发现对一些人有用
3.希望STM 的LL库越来越好用
也不要看到别人否决了,就萎下去了。。。要勇于反抗!!!拿出证据,一步一步认证举例。。。打别人得脸可是很好玩得事情,滑稽。。。问题嘛,就是在反复探讨中成长,但是,一切都有但是,作为个人,很多东西,不要动不动就说别人这不行,那不行,比如你这标题起的,官方LL库bug太多,直接就表明了LL垃圾的一逼啊,感觉就像一以前UC震惊部。。。怎么问才合适呢,比如:官方得LL库这里好像有个bug,不知各位有木有遇到。。。谦虚一点,毕竟个人再牛逼,能力都是由限的!!!
lqs0905 回答时间:2018-11-30 16:58:09
ErrorStatus LL_GPIO_Init(GPIO_TypeDef *GPIOx, LL_GPIO_InitTypeDef *GPIO_InitStruct)
  uint32_t pinmask;
  uint32_t pinpos;
  uint32_t currentpin;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_INSTANCE(GPIOx));
  assert_param(IS_LL_GPIO_PIN(GPIO_InitStruct->Pin));
  /* ------------------------- Configure the port pins ---------------- */
  /* Initialize  pinpos on first pin set */
  pinmask = ((GPIO_InitStruct->Pin) << GPIO_PIN_MASK_POS) >> GPIO_PIN_NB;
  pinpos = POSITION_VAL(pinmask);
  /* Configure the port pins */
  while ((pinmask  >> pinpos) != 0U)
    /* skip if bit is not set */
    if ((pinmask & (1U << pinpos)) != 0U)
      /* Get current io position */
      if (pinpos < GPIO_PIN_MASK_POS)
        currentpin = (0x00000101U << pinpos);
      else
        currentpin = ((0x00010001U << (pinpos - GPIO_PIN_MASK_POS)) | 0x04000000U);
      /* Check Pin Mode and Pin Pull parameters */
      assert_param(IS_LL_GPIO_MODE(GPIO_InitStruct->Mode));
      assert_param(IS_LL_GPIO_PULL(GPIO_InitStruct->Pull));
      /* Pin Mode configuration */
      LL_GPIO_SetPinMode(GPIOx, currentpin, GPIO_InitStruct->Mode);
      /* Pull-up Pull-down resistor configuration*/
      LL_GPIO_SetPinPull(GPIOx, currentpin, GPIO_InitStruct->Pull);//这是一个BUG这一行不管设成输入输去都会执行
      if ((GPIO_InitStruct->Mode == LL_GPIO_MODE_OUTPUT) || (GPIO_InitStruct->Mode == LL_GPIO_MODE_ALTERNATE))
        /* Check speed and Output mode parameters */
        assert_param(IS_LL_GPIO_SPEED(GPIO_InitStruct->Speed));
        assert_param(IS_LL_GPIO_OUTPUT_TYPE(GPIO_InitStruct->OutputType));
        /* Speed mode configuration */
        LL_GPIO_SetPinSpeed(GPIOx, currentpin, GPIO_InitStruct->Speed);
        /* Output mode configuration*/
        LL_GPIO_SetPinOutputType(GPIOx, currentpin, GPIO_InitStruct->OutputType);
    pinpos++;
  return (SUCCESS);
caoenq 回答时间:2019-11-1 14:13:11
MrJiu 发表于 2018-11-30 13:42
HAL和LL本身都是都是对寄存器的封装,至于功能的实现,那不叫bug,那叫未实现,或者说是功能不提供!!!而 ...
版主大人说话尖酸、刻薄,但是说的非常有道理。
12
STM32团队
最新内容
