STM32F103利用DMA控制PWM占空比出现错误
crashdown 提问时间:2016-12-23 10:39 /
收藏 1 评论12 发布时间:2016-12-23 10:39
12个回答
shuolang126 回答时间:2016-12-31 08:12:26
官方例程,供你参考!
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define TIM1_CCR3_Address    0x40012C3C
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t SRC_Buffer[3] = {0, 0, 0};
uint16_t TimerPeriod = 0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void DMA_Configuration(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  RCC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* DMA Configuration */
  DMA_Configuration();
  /* TIM1 DMA Transfer example -------------------------------------------------
  TIM1CLK = SystemCoreClock, Prescaler = 0, TIM1 counter clock = SystemCoreClock
  SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density
  and Connectivity line devices and to 24 MHz for Low-Density Value line and
  Medium-Density Value line devices.
  The objective is to configure TIM1 channel 3 to generate complementary PWM
  signal with a frequency equal to 17.57 KHz:
     - TIM1_Period = (SystemCoreClock / 17570) - 1
  and a variable duty cycle that is changed by the DMA after a specific number of
  Update DMA request.
  The number of this repetitive requests is defined by the TIM1 Repetition counter,
  each 3 Update Requests, the TIM1 Channel 3 Duty Cycle changes to the next new
  value defined by the SRC_Buffer .
  /* Compute the value to be set in ARR register to generate signal frequency at 17.57 Khz */
  TimerPeriod = (SystemCoreClock / 17570 ) - 1;
  /* Compute CCR1 value to generate a duty cycle at 50% */
  SRC_Buffer[0] = (uint16_t) (((uint32_t) 5 * (TimerPeriod - 1)) / 10);
  /* Compute CCR1 value to generate a duty cycle at 37.5% */
  SRC_Buffer[1] = (uint16_t) (((uint32_t) 375 * (TimerPeriod - 1)) / 1000);
  /* Compute CCR1 value to generate a duty cycle at 25% */
  SRC_Buffer[2] = (uint16_t) (((uint32_t) 25 * (TimerPeriod - 1)) / 100);
  /* TIM1 Peripheral Configuration --------------------------------------------*/
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 2;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* Channel 3 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = SRC_Buffer[0];
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 Update DMA Request enable */
  TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  while (1)
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
  /* TIM1, GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
                         RCC_APB2Periph_GPIOB, ENABLE);
  /* DMA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  * @brief  Configure the TIM1 Pins.
  * @param  None
  * @retval None
  /* GPIOA Configuration: Channel 3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
  /* GPIOB Configuration: Channel 3N as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  * @brief  Configures the DMA.
  * @param  None
  * @retval None
  DMA_InitTypeDef DMA_InitStructure;
  /* DMA1 Channel5 Config */
  DMA_DeInit(DMA1_Channel5);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_CCR3_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = 3;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel5, &DMA_InitStructure);
  /* DMA1 Channel5 enable */
  DMA_Cmd(DMA1_Channel5, ENABLE);
参与人数 1ST金币 +2 收起 理由
shuolang126 回答时间:2016-12-31 08:13:15
官方提供了很多外设的使用例程,多看看还是有帮助的
zbber 回答时间:2016-12-31 10:32:15
累加和累减的程序看一下
12
