分享一个工具,把Nucleo板载的STlink变成Jlink或者还原为STlink
wofei1314 发布时间:2016-10-18 14:01
1 收藏 3 评论12 发布时间:2016-10-18 14:01
12个回答
moyanming2013 回答时间:2017-1-6 11:03:45
wolfgang2015 发表于 2016-12-15 20:52
没用过,没资料,没手册,没介绍的三没产品,不敢用~~
早前有人发过此类应用:
https://www.stmcu.org.cn/module/ ... =page%3D&page=1
但我建议不要用!:
ST-LINK也是用的SWD方式,可选4MHz,关键替换后估计不稳定,为什么要替换?!
更重要的是,刷成jlink后一堆限制,建议不要刷了:
Limitations
The firmware making the ST-LINK on-board J-Link compatible has some limitations in contrast to an original, industry leading SEGGER J-Link:
1.May be used with ARM based ST devices only
2.Only debugging on evaluation boards is allowed. Debugging on custom hardware is not supported and not allowed
3.No production flash programming support
4.Unlimited breakpoints in flash available for evaluation only
5.No support is given
参考:
http://www.segger.com/jlink-st-link.html
zbber 回答时间:2017-1-6 15:24:03
,强烈支持楼主ing……
David Zou 回答时间:2017-5-1 16:24:07
谢谢楼主分享
12
STM32团队
最新内容
