Mbed 导出到MDK编译不通过的解决办法-已解决,
anywill 发布时间:2016-10-2 19:39
收藏 1 评论20 发布时间:2016-10-2 19:39
20个回答
jy04706985 回答时间:2019-10-21 21:40:45
遇到同样问题了,解决不了,,,导出到jkeil 5编译很多错误。。。。Build target 'mbed-os-example-blinky'
compiling 6lowpan_iphc.c...
Fatal error: C3907U: Via file '.\build\6lowpan_iphc.__i' command too long for buffer.
compiling ac_buffer.c...
Fatal error: C3907U: Via file '.\build\ac_buffer.__i' command too long for buffer.
compiling ac_buffer_builder.c...
Fatal error: C3907U: Via file '.\build\ac_buffer_builder.__i' command too long for buffer.
compiling ac_buffer_reader.c...
Fatal error: C3907U: Via file '.\build\ac_buffer_reader.__i' command too long for buffer.
compiling ac_stream.c...
Fatal error: C3907U: Via file '.\build\ac_stream.__i' command too long for buffer.
compiling adaptation_interface.c...
Fatal error: C3907U: Via file '.\build\adaptation_interface.__i' command too long for buffer.
compiling aes.c...
Fatal error: C3907U: Via file '.\build\aes.__i' command too long for buffer.
compiling aes_alt.c...
Fatal error: C3907U: Via file '.\build\aes_alt.__i' command too long for buffer.
compiling aes_mbedtls_adapter.c...
Fatal error: C3907U: Via file '.\build\aes_mbedtls_adapter.__i' command too long for buffer.
compiling aesni.c...
Fatal error: C3907U: Via file '.\build\aesni.__i' command too long for buffer.
compiling AnalogIn.cpp...
Fatal error: C3907U: Via file '.\build\analogin.__i' command too long for buffer.
compiling analogin_api.c...
Fatal error: C3907U: Via file '.\build\analogin_api.__i' command too long for buffer.
compiling analogin_device.c...
Fatal error: C3907U: Via file '.\build\analogin_device.__i' command too long for buffer.
compiling AnalogOut.cpp...
Fatal error: C3907U: Via file '.\build\analogout.__i' command too long for buffer.
compiling analogout_api.c...
Fatal error: C3907U: Via file '.\build\analogout_api.__i' command too long for buffer.
compiling analogout_device.c...
Fatal error: C3907U: Via file '.\build\analogout_device.__i' command too long for buffer.
compiling APN_db.cpp...
Fatal error: C3907U: Via file '.\build\apn_db.__i' command too long for buffer.
compiling arc4.c...
Fatal error: C3907U: Via file '.\build\arc4.__i' command too long for buffer.
compiling aria.c...
Fatal error: C3907U: Via file '.\build\aria.__i' command too long for buffer.
compiling arm_hal_fhss_timer.cpp...
Fatal error: C3907U: Via file '.\build\arm_hal_fhss_timer.__i' command too long for buffer.
compiling arm_hal_interrupt.c...
Fatal error: C3907U: Via file '.\build\arm_hal_interrupt.__i' command too long for buffer.
compiling arm_hal_random.c...
Fatal error: C3907U: Via file '.\build\arm_hal_random.__i' command too long for buffer.
compiling arm_hal_timer.cpp...
Fatal error: C3907U: Via file '.\build\arm_hal_timer.__i' command too long for buffer.
compiling asn1parse.c...
Fatal error: C3907U: Via file '.\build\asn1parse.__i' command too long for buffer.
compiling asn1write.c...
Fatal error: C3907U: Via file '.\build\asn1write.__i' command too long for buffer.
compiling AsyncOp.cpp...
Fatal error: C3907U: Via file '.\build\asyncop.__i' command too long for buffer.
compiling at24mac.cpp...
Fatal error: C3907U: Via file '.\build\at24mac.__i' command too long for buffer.
compiling at24mac_s2lp.cpp...
Fatal error: C3907U: Via file '.\build\at24mac_s2lp.__i' command too long for buffer.
compiling AT_CellularBase.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularbase.__i' command too long for buffer.
compiling AT_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularcontext.__i' command too long for buffer.
compiling AT_CellularDevice.cpp...
Fatal error: C3907U: Via file '.\build\at_cellulardevice.__i' command too long for buffer.
compiling AT_CellularInformation.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularinformation.__i' command too long for buffer.
compiling AT_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularnetwork.__i' command too long for buffer.
compiling AT_CellularSMS.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularsms.__i' command too long for buffer.
compiling AT_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\at_cellularstack.__i' command too long for buffer.
compiling AT_ControlPlane_netif.cpp...
Fatal error: C3907U: Via file '.\build\at_controlplane_netif.__i' command too long for buffer.
compiling ATCmdParser.cpp...
Fatal error: C3907U: Via file '.\build\atcmdparser.__i' command too long for buffer.
compiling ATHandler.cpp...
Fatal error: C3907U: Via file '.\build\athandler.__i' command too long for buffer.
compiling auth.c...
Fatal error: C3907U: Via file '.\build\auth.__i' command too long for buffer.
compiling auth_eap_tls_sec_prot.c...
Fatal error: C3907U: Via file '.\build\auth_eap_tls_sec_prot.__i' command too long for buffer.
compiling auth_fwh_sec_prot.c...
Fatal error: C3907U: Via file '.\build\auth_fwh_sec_prot.__i' command too long for buffer.
compiling auth_gkh_sec_prot.c...
Fatal error: C3907U: Via file '.\build\auth_gkh_sec_prot.__i' command too long for buffer.
compiling base64.c...
Fatal error: C3907U: Via file '.\build\base64.__i' command too long for buffer.
compiling beacon_handler.c...
Fatal error: C3907U: Via file '.\build\beacon_handler.__i' command too long for buffer.
compiling bignum.c...
Fatal error: C3907U: Via file '.\build\bignum.__i' command too long for buffer.
compiling blacklist.c...
Fatal error: C3907U: Via file '.\build\blacklist.__i' command too long for buffer.
compiling blowfish.c...
Fatal error: C3907U: Via file '.\build\blowfish.__i' command too long for buffer.
compiling border_router.c...
Fatal error: C3907U: Via file '.\build\border_router.__i' command too long for buffer.
compiling buffer_dyn.c...
Fatal error: C3907U: Via file '.\build\buffer_dyn.__i' command too long for buffer.
compiling BufferedBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\bufferedblockdevice.__i' command too long for buffer.
compiling BusIn.cpp...
Fatal error: C3907U: Via file '.\build\busin.__i' command too long for buffer.
compiling BusInOut.cpp...
Fatal error: C3907U: Via file '.\build\businout.__i' command too long for buffer.
compiling BusOut.cpp...
Fatal error: C3907U: Via file '.\build\busout.__i' command too long for buffer.
compiling ByteBuffer.cpp...
Fatal error: C3907U: Via file '.\build\bytebuffer.__i' command too long for buffer.
compiling CallbackHandler.cpp...
Fatal error: C3907U: Via file '.\build\callbackhandler.__i' command too long for buffer.
compiling CallChain.cpp...
Fatal error: C3907U: Via file '.\build\callchain.__i' command too long for buffer.
compiling camellia.c...
Fatal error: C3907U: Via file '.\build\camellia.__i' command too long for buffer.
compiling CAN.cpp...
Fatal error: C3907U: Via file '.\build\can.__i' command too long for buffer.
compiling can_api.c...
Fatal error: C3907U: Via file '.\build\can_api.__i' command too long for buffer.
compiling ccm.c...
Fatal error: C3907U: Via file '.\build\ccm.__i' command too long for buffer.
compiling ccm_security.c...
Fatal error: C3907U: Via file '.\build\ccm_security.__i' command too long for buffer.
compiling ccp.c...
Fatal error: C3907U: Via file '.\build\ccp.__i' command too long for buffer.
compiling CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\cellularcontext.__i' command too long for buffer.
compiling CellularDevice.cpp...
Fatal error: C3907U: Via file '.\build\cellulardevice.__i' command too long for buffer.
compiling CellularLog.cpp...
Fatal error: C3907U: Via file '.\build\cellularlog.__i' command too long for buffer.
compiling CellularNonIPSocket.cpp...
Fatal error: C3907U: Via file '.\build\cellularnonipsocket.__i' command too long for buffer.
compiling CellularStateMachine.cpp...
Fatal error: C3907U: Via file '.\build\cellularstatemachine.__i' command too long for buffer.
compiling CellularUtil.cpp...
Fatal error: C3907U: Via file '.\build\cellularutil.__i' command too long for buffer.
compiling certs.c...
Fatal error: C3907U: Via file '.\build\certs.__i' command too long for buffer.
compiling chacha20.c...
Fatal error: C3907U: Via file '.\build\chacha20.__i' command too long for buffer.
compiling chachapoly.c...
Fatal error: C3907U: Via file '.\build\chachapoly.__i' command too long for buffer.
compiling ChainingBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\chainingblockdevice.__i' command too long for buffer.
compiling channel_functions.c...
Fatal error: C3907U: Via file '.\build\channel_functions.__i' command too long for buffer.
compiling channel_list.c...
Fatal error: C3907U: Via file '.\build\channel_list.__i' command too long for buffer.
compiling chap-md5.c...
Fatal error: C3907U: Via file '.\build\chap-md5.__i' command too long for buffer.
compiling chap-new.c...
Fatal error: C3907U: Via file '.\build\chap-new.__i' command too long for buffer.
compiling chap_ms.c...
Fatal error: C3907U: Via file '.\build\chap_ms.__i' command too long for buffer.
compiling cipher.c...
Fatal error: C3907U: Via file '.\build\cipher.__i' command too long for buffer.
compiling cipher_wrap.c...
Fatal error: C3907U: Via file '.\build\cipher_wrap.__i' command too long for buffer.
compiling cipv6_fragmenter.c...
Fatal error: C3907U: Via file '.\build\cipv6_fragmenter.__i' command too long for buffer.
compiling cmac.c...
Fatal error: C3907U: Via file '.\build\cmac.__i' command too long for buffer.
compiling cmsis_nvic.c...
Fatal error: C3907U: Via file '.\build\cmsis_nvic.__i' command too long for buffer.
compiling cmsis_os1.c...
Fatal error: C3907U: Via file '.\build\cmsis_os1.__i' command too long for buffer.
compiling coap_connection_handler.c...
Fatal error: C3907U: Via file '.\build\coap_connection_handler.__i' command too long for buffer.
compiling coap_message_handler.c...
Fatal error: C3907U: Via file '.\build\coap_message_handler.__i' command too long for buffer.
compiling coap_security_handler.c...
Fatal error: C3907U: Via file '.\build\coap_security_handler.__i' command too long for buffer.
compiling coap_service_api.c...
Fatal error: C3907U: Via file '.\build\coap_service_api.__i' command too long for buffer.
compiling common_functions.c...
Fatal error: C3907U: Via file '.\build\common_functions.__i' command too long for buffer.
compiling ConditionVariable.cpp...
Fatal error: C3907U: Via file '.\build\conditionvariable.__i' command too long for buffer.
compiling CriticalSectionLock.cpp...
Fatal error: C3907U: Via file '.\build\criticalsectionlock.__i' command too long for buffer.
compiling CThunkBase.cpp...
Fatal error: C3907U: Via file '.\build\cthunkbase.__i' command too long for buffer.
compiling ctr_drbg.c...
Fatal error: C3907U: Via file '.\build\ctr_drbg.__i' command too long for buffer.
compiling debug.c...
Fatal error: C3907U: Via file '.\build\debug.__i' command too long for buffer.
compiling DeepSleepLock.cpp...
Fatal error: C3907U: Via file '.\build\deepsleeplock.__i' command too long for buffer.
compiling demand.c...
Fatal error: C3907U: Via file '.\build\demand.__i' command too long for buffer.
compiling des.c...
Fatal error: C3907U: Via file '.\build\des.__i' command too long for buffer.
compiling DeviceKey.cpp...
Fatal error: C3907U: Via file '.\build\devicekey.__i' command too long for buffer.
compiling dhcp_service_api.c...
Fatal error: C3907U: Via file '.\build\dhcp_service_api.__i' command too long for buffer.
compiling dhcpv6_client_service.c...
Fatal error: C3907U: Via file '.\build\dhcpv6_client_service.__i' command too long for buffer.
compiling DHCPv6_Server_service.c...
Fatal error: C3907U: Via file '.\build\dhcpv6_server_service.__i' command too long for buffer.
compiling dhm.c...
Fatal error: C3907U: Via file '.\build\dhm.__i' command too long for buffer.
compiling DigitalIn.cpp...
Fatal error: C3907U: Via file '.\build\digitalin.__i' command too long for buffer.
compiling DigitalInOut.cpp...
Fatal error: C3907U: Via file '.\build\digitalinout.__i' command too long for buffer.
compiling DigitalOut.cpp...
Fatal error: C3907U: Via file '.\build\digitalout.__i' command too long for buffer.
compiling Dir.cpp...
Fatal error: C3907U: Via file '.\build\dir.__i' command too long for buffer.
compiling DirectAccessDevicekey.cpp...
Fatal error: C3907U: Via file '.\build\directaccessdevicekey.__i' command too long for buffer.
compiling DTLSSocket.cpp...
Fatal error: C3907U: Via file '.\build\dtlssocket.__i' command too long for buffer.
compiling DTLSSocketWrapper.cpp...
Fatal error: C3907U: Via file '.\build\dtlssocketwrapper.__i' command too long for buffer.
compiling eap.c...
Fatal error: C3907U: Via file '.\build\eap.__i' command too long for buffer.
compiling eap_protocol.c...
Fatal error: C3907U: Via file '.\build\eap_protocol.__i' command too long for buffer.
compiling eap_tls_sec_prot_lib.c...
Fatal error: C3907U: Via file '.\build\eap_tls_sec_prot_lib.__i' command too long for buffer.
compiling eapol_helper.c...
Fatal error: C3907U: Via file '.\build\eapol_helper.__i' command too long for buffer.
compiling ecdh.c...
Fatal error: C3907U: Via file '.\build\ecdh.__i' command too long for buffer.
compiling ecdsa.c...
Fatal error: C3907U: Via file '.\build\ecdsa.__i' command too long for buffer.
compiling ecjpake.c...
Fatal error: C3907U: Via file '.\build\ecjpake.__i' command too long for buffer.
compiling ecp.c...
Fatal error: C3907U: Via file '.\build\ecp.__i' command too long for buffer.
compiling ecp_curves.c...
Fatal error: C3907U: Via file '.\build\ecp_curves.__i' command too long for buffer.
compiling EMACInterface.cpp...
Fatal error: C3907U: Via file '.\build\emacinterface.__i' command too long for buffer.
compiling EndpointResolver.cpp...
Fatal error: C3907U: Via file '.\build\endpointresolver.__i' command too long for buffer.
compiling entropy.c...
Fatal error: C3907U: Via file '.\build\entropy.__i' command too long for buffer.
compiling entropy_poll.c...
Fatal error: C3907U: Via file '.\build\entropy_poll.__i' command too long for buffer.
compiling equeue.c...
Fatal error: C3907U: Via file '.\build\equeue.__i' command too long for buffer.
compiling equeue_mbed.cpp...
Fatal error: C3907U: Via file '.\build\equeue_mbed.__i' command too long for buffer.
compiling equeue_posix.c...
Fatal error: C3907U: Via file '.\build\equeue_posix.__i' command too long for buffer.
compiling error.c...
Fatal error: C3907U: Via file '.\build\error.__i' command too long for buffer.
compiling ESP8266.cpp...
Fatal error: C3907U: Via file '.\build\esp8266.__i' command too long for buffer.
compiling ESP8266Interface.cpp...
Fatal error: C3907U: Via file '.\build\esp8266interface.__i' command too long for buffer.
compiling Ethernet.cpp...
Fatal error: C3907U: Via file '.\build\ethernet.__i' command too long for buffer.
compiling ethernet_mac_api.c...
Fatal error: C3907U: Via file '.\build\ethernet_mac_api.__i' command too long for buffer.
compiling ethernet_tasklet.c...
Fatal error: C3907U: Via file '.\build\ethernet_tasklet.__i' command too long for buffer.
compiling EthernetInterface.cpp...
Fatal error: C3907U: Via file '.\build\ethernetinterface.__i' command too long for buffer.
compiling etx.c...
Fatal error: C3907U: Via file '.\build\etx.__i' command too long for buffer.
compiling eui64.c...
Fatal error: C3907U: Via file '.\build\eui64.__i' command too long for buffer.
compiling event.c...
Fatal error: C3907U: Via file '.\build\event.__i' command too long for buffer.
compiling EventFlags.cpp...
Fatal error: C3907U: Via file '.\build\eventflags.__i' command too long for buffer.
compiling EventQueue.cpp...
Fatal error: C3907U: Via file '.\build\eventqueue.__i' command too long for buffer.
compiling ExhaustibleBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\exhaustibleblockdevice.__i' command too long for buffer.
compiling FATFileSystem.cpp...
Fatal error: C3907U: Via file '.\build\fatfilesystem.__i' command too long for buffer.
compiling ff.cpp...
Fatal error: C3907U: Via file '.\build\ff.__i' command too long for buffer.
compiling ffunicode.cpp...
Fatal error: C3907U: Via file '.\build\ffunicode.__i' command too long for buffer.
compiling fhss.c...
Fatal error: C3907U: Via file '.\build\fhss.__i' command too long for buffer.
compiling fhss_channel.c...
Fatal error: C3907U: Via file '.\build\fhss_channel.__i' command too long for buffer.
compiling fhss_common.c...
Fatal error: C3907U: Via file '.\build\fhss_common.__i' command too long for buffer.
compiling fhss_configuration_interface.c...
Fatal error: C3907U: Via file '.\build\fhss_configuration_interface.__i' command too long for buffer.
compiling fhss_statistics.c...
Fatal error: C3907U: Via file '.\build\fhss_statistics.__i' command too long for buffer.
compiling fhss_ws.c...
Fatal error: C3907U: Via file '.\build\fhss_ws.__i' command too long for buffer.
compiling fhss_ws_empty_functions.c...
Fatal error: C3907U: Via file '.\build\fhss_ws_empty_functions.__i' command too long for buffer.
compiling File.cpp...
Fatal error: C3907U: Via file '.\build\file.__i' command too long for buffer.
compiling FileBase.cpp...
Fatal error: C3907U: Via file '.\build\filebase.__i' command too long for buffer.
compiling FileHandle.cpp...
Fatal error: C3907U: Via file '.\build\filehandle.__i' command too long for buffer.
compiling FilePath.cpp...
Fatal error: C3907U: Via file '.\build\filepath.__i' command too long for buffer.
compiling FileSystem.cpp...
Fatal error: C3907U: Via file '.\build\filesystem.__i' command too long for buffer.
compiling FileSystemHandle.cpp...
Fatal error: C3907U: Via file '.\build\filesystemhandle.__i' command too long for buffer.
compiling FileSystemStore.cpp...
Fatal error: C3907U: Via file '.\build\filesystemstore.__i' command too long for buffer.
compiling flash_api.c...
Fatal error: C3907U: Via file '.\build\flash_api.__i' command too long for buffer.
compiling FlashIAP.cpp...
Fatal error: C3907U: Via file '.\build\flashiap.__i' command too long for buffer.
compiling FlashSimBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\flashsimblockdevice.__i' command too long for buffer.
compiling fnet_mdns.c...
Fatal error: C3907U: Via file '.\build\fnet_mdns.__i' command too long for buffer.
compiling fnet_poll.c...
Fatal error: C3907U: Via file '.\build\fnet_poll.__i' command too long for buffer.
compiling fnet_stdlib.c...
Fatal error: C3907U: Via file '.\build\fnet_stdlib.__i' command too long for buffer.
compiling fnv_hash.c...
Fatal error: C3907U: Via file '.\build\fnv_hash.__i' command too long for buffer.
compiling fsm.c...
Fatal error: C3907U: Via file '.\build\fsm.__i' command too long for buffer.
compiling gcm.c...
Fatal error: C3907U: Via file '.\build\gcm.__i' command too long for buffer.
compiling GEMALTO_CINTERION.cpp...
Fatal error: C3907U: Via file '.\build\gemalto_cinterion.__i' command too long for buffer.
compiling GEMALTO_CINTERION_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\gemalto_cinterion_cellularcontext.__i' command too long for buffer.
compiling GEMALTO_CINTERION_CellularInformation.cpp...
Fatal error: C3907U: Via file '.\build\gemalto_cinterion_cellularinformation.__i' command too long for buffer.
compiling GEMALTO_CINTERION_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\gemalto_cinterion_cellularstack.__i' command too long for buffer.
compiling GENERIC_AT3GPP.cpp...
Fatal error: C3907U: Via file '.\build\generic_at3gpp.__i' command too long for buffer.
compiling gpio_api.c...
Fatal error: C3907U: Via file '.\build\gpio_api.__i' command too long for buffer.
compiling gpio_irq_api.c...
Fatal error: C3907U: Via file '.\build\gpio_irq_api.__i' command too long for buffer.
compiling gpio_irq_device.c...
Fatal error: C3907U: Via file '.\build\gpio_irq_device.__i' command too long for buffer.
compiling greentea_metrics.cpp...
Fatal error: C3907U: Via file '.\build\greentea_metrics.__i' command too long for buffer.
compiling greentea_serial.cpp...
Fatal error: C3907U: Via file '.\build\greentea_serial.__i' command too long for buffer.
compiling greentea_test_env.cpp...
Fatal error: C3907U: Via file '.\build\greentea_test_env.__i' command too long for buffer.
compiling hal_tick_overrides.c...
Fatal error: C3907U: Via file '.\build\hal_tick_overrides.__i' command too long for buffer.
compiling hash_wrappers.c...
Fatal error: C3907U: Via file '.\build\hash_wrappers.__i' command too long for buffer.
compiling havege.c...
Fatal error: C3907U: Via file '.\build\havege.__i' command too long for buffer.
compiling HeapBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\heapblockdevice.__i' command too long for buffer.
compiling hkdf.c...
Fatal error: C3907U: Via file '.\build\hkdf.__i' command too long for buffer.
compiling hmac_drbg.c...
Fatal error: C3907U: Via file '.\build\hmac_drbg.__i' command too long for buffer.
compiling hmac_sha1.c...
Fatal error: C3907U: Via file '.\build\hmac_sha1.__i' command too long for buffer.
compiling I2C.cpp...
Fatal error: C3907U: Via file '.\build\i2c.__i' command too long for buffer.
compiling i2c_api.c...
Fatal error: C3907U: Via file '.\build\i2c_api.__i' command too long for buffer.
compiling I2CSlave.cpp...
Fatal error: C3907U: Via file '.\build\i2cslave.__i' command too long for buffer.
compiling icmpv6.c...
Fatal error: C3907U: Via file '.\build\icmpv6.__i' command too long for buffer.
compiling icmpv6_prefix.c...
Fatal error: C3907U: Via file '.\build\icmpv6_prefix.__i' command too long for buffer.
compiling icmpv6_radv.c...
Fatal error: C3907U: Via file '.\build\icmpv6_radv.__i' command too long for buffer.
compiling ieee_802_11.c...
Fatal error: C3907U: Via file '.\build\ieee_802_11.__i' command too long for buffer.
compiling InternetSocket.cpp...
Fatal error: C3907U: Via file '.\build\internetsocket.__i' command too long for buffer.
compiling InterruptIn.cpp...
Fatal error: C3907U: Via file '.\build\interruptin.__i' command too long for buffer.
compiling InterruptManager.cpp...
Fatal error: C3907U: Via file '.\build\interruptmanager.__i' command too long for buffer.
compiling ip4tos.c...
Fatal error: C3907U: Via file '.\build\ip4tos.__i' command too long for buffer.
compiling ip6tos.c...
Fatal error: C3907U: Via file '.\build\ip6tos.__i' command too long for buffer.
compiling ip_fsc.c...
Fatal error: C3907U: Via file '.\build\ip_fsc.__i' command too long for buffer.
compiling ipcp.c...
Fatal error: C3907U: Via file '.\build\ipcp.__i' command too long for buffer.
compiling iphc_compress.c...
Fatal error: C3907U: Via file '.\build\iphc_compress.__i' command too long for buffer.
compiling iphc_decompress.c...
Fatal error: C3907U: Via file '.\build\iphc_decompress.__i' command too long for buffer.
compiling ipv6.c...
Fatal error: C3907U: Via file '.\build\ipv6.__i' command too long for buffer.
compiling ipv6_flow.c...
Fatal error: C3907U: Via file '.\build\ipv6_flow.__i' command too long for buffer.
compiling ipv6_fragmentation.c...
Fatal error: C3907U: Via file '.\build\ipv6_fragmentation.__i' command too long for buffer.
compiling ipv6_resolution.c...
Fatal error: C3907U: Via file '.\build\ipv6_resolution.__i' command too long for buffer.
compiling ipv6_routing_table.c...
Fatal error: C3907U: Via file '.\build\ipv6_routing_table.__i' command too long for buffer.
compiling ipv6cp.c...
Fatal error: C3907U: Via file '.\build\ipv6cp.__i' command too long for buffer.
compiling iso7816.c...
Fatal error: C3907U: Via file '.\build\iso7816.__i' command too long for buffer.
compiling iso7816_app.c...
Fatal error: C3907U: Via file '.\build\iso7816_app.__i' command too long for buffer.
compiling isodep_target.c...
Fatal error: C3907U: Via file '.\build\isodep_target.__i' command too long for buffer.
compiling isqrt.c...
Fatal error: C3907U: Via file '.\build\isqrt.__i' command too long for buffer.
compiling kde_helper.c...
Fatal error: C3907U: Via file '.\build\kde_helper.__i' command too long for buffer.
compiling Kernel.cpp...
Fatal error: C3907U: Via file '.\build\kernel.__i' command too long for buffer.
compiling key_sec_prot.c...
Fatal error: C3907U: Via file '.\build\key_sec_prot.__i' command too long for buffer.
compiling kmp_addr.c...
Fatal error: C3907U: Via file '.\build\kmp_addr.__i' command too long for buffer.
compiling kmp_api.c...
Fatal error: C3907U: Via file '.\build\kmp_api.__i' command too long for buffer.
compiling kmp_eapol_pdu_if.c...
Fatal error: C3907U: Via file '.\build\kmp_eapol_pdu_if.__i' command too long for buffer.
compiling kmp_socket_if.c...
Fatal error: C3907U: Via file '.\build\kmp_socket_if.__i' command too long for buffer.
compiling kv_config.cpp...
Fatal error: C3907U: Via file '.\build\kv_config.__i' command too long for buffer.
compiling KVMap.cpp...
Fatal error: C3907U: Via file '.\build\kvmap.__i' command too long for buffer.
compiling kvstore_global_api.cpp...
Fatal error: C3907U: Via file '.\build\kvstore_global_api.__i' command too long for buffer.
compiling L3IPInterface.cpp...
Fatal error: C3907U: Via file '.\build\l3ipinterface.__i' command too long for buffer.
compiling lcp.c...
Fatal error: C3907U: Via file '.\build\lcp.__i' command too long for buffer.
compiling lfs.c...
Fatal error: C3907U: Via file '.\build\lfs.__i' command too long for buffer.
compiling lfs_util.c...
Fatal error: C3907U: Via file '.\build\lfs_util.__i' command too long for buffer.
compiling libDHCPv6.c...
Fatal error: C3907U: Via file '.\build\libdhcpv6.__i' command too long for buffer.
compiling libDHCPv6_server.c...
Fatal error: C3907U: Via file '.\build\libdhcpv6_server.__i' command too long for buffer.
compiling LinkedListBase.cpp...
Fatal error: C3907U: Via file '.\build\linkedlistbase.__i' command too long for buffer.
compiling LittleFileSystem.cpp...
Fatal error: C3907U: Via file '.\build\littlefilesystem.__i' command too long for buffer.
compiling load_balance.c...
Fatal error: C3907U: Via file '.\build\load_balance.__i' command too long for buffer.
compiling LocalFileSystem.cpp...
Fatal error: C3907U: Via file '.\build\localfilesystem.__i' command too long for buffer.
compiling LoRaMac.cpp...
Fatal error: C3907U: Via file '.\build\loramac.__i' command too long for buffer.
compiling LoRaMacChannelPlan.cpp...
Fatal error: C3907U: Via file '.\build\loramacchannelplan.__i' command too long for buffer.
compiling LoRaMacCommand.cpp...
Fatal error: C3907U: Via file '.\build\loramaccommand.__i' command too long for buffer.
compiling LoRaMacCrypto.cpp...
Fatal error: C3907U: Via file '.\build\loramaccrypto.__i' command too long for buffer.
compiling LoRaPHY.cpp...
Fatal error: C3907U: Via file '.\build\loraphy.__i' command too long for buffer.
compiling LoRaPHYAS923.cpp...
Fatal error: C3907U: Via file '.\build\loraphyas923.__i' command too long for buffer.
compiling LoRaPHYAU915.cpp...
Fatal error: C3907U: Via file '.\build\loraphyau915.__i' command too long for buffer.
compiling LoRaPHYCN470.cpp...
Fatal error: C3907U: Via file '.\build\loraphycn470.__i' command too long for buffer.
compiling LoRaPHYCN779.cpp...
Fatal error: C3907U: Via file '.\build\loraphycn779.__i' command too long for buffer.
compiling LoRaPHYEU433.cpp...
Fatal error: C3907U: Via file '.\build\loraphyeu433.__i' command too long for buffer.
compiling LoRaPHYEU868.cpp...
Fatal error: C3907U: Via file '.\build\loraphyeu868.__i' command too long for buffer.
compiling LoRaPHYIN865.cpp...
Fatal error: C3907U: Via file '.\build\loraphyin865.__i' command too long for buffer.
compiling LoRaPHYKR920.cpp...
Fatal error: C3907U: Via file '.\build\loraphykr920.__i' command too long for buffer.
compiling LoRaPHYUS915.cpp...
Fatal error: C3907U: Via file '.\build\loraphyus915.__i' command too long for buffer.
compiling LoRaWANInterface.cpp...
Fatal error: C3907U: Via file '.\build\lorawaninterface.__i' command too long for buffer.
compiling LoRaWANStack.cpp...
Fatal error: C3907U: Via file '.\build\lorawanstack.__i' command too long for buffer.
compiling LoRaWANTimer.cpp...
Fatal error: C3907U: Via file '.\build\lorawantimer.__i' command too long for buffer.
compiling lowpan_context.c...
Fatal error: C3907U: Via file '.\build\lowpan_context.__i' command too long for buffer.
compiling LoWPANNDInterface.cpp...
Fatal error: C3907U: Via file '.\build\lowpanndinterface.__i' command too long for buffer.
compiling LowPowerTickerWrapper.cpp...
Fatal error: C3907U: Via file '.\build\lowpowertickerwrapper.__i' command too long for buffer.
compiling lp_ticker.c...
Fatal error: C3907U: Via file '.\build\lp_ticker.__i' command too long for buffer.
compiling lwip_altcp.c...
Fatal error: C3907U: Via file '.\build\lwip_altcp.__i' command too long for buffer.
compiling lwip_altcp_alloc.c...
Fatal error: C3907U: Via file '.\build\lwip_altcp_alloc.__i' command too long for buffer.
compiling lwip_altcp_tcp.c...
Fatal error: C3907U: Via file '.\build\lwip_altcp_tcp.__i' command too long for buffer.
compiling lwip_api_lib.c...
Fatal error: C3907U: Via file '.\build\lwip_api_lib.__i' command too long for buffer.
compiling lwip_api_msg.c...
Fatal error: C3907U: Via file '.\build\lwip_api_msg.__i' command too long for buffer.
compiling lwip_autoip.c...
Fatal error: C3907U: Via file '.\build\lwip_autoip.__i' command too long for buffer.
compiling lwip_bridgeif.c...
Fatal error: C3907U: Via file '.\build\lwip_bridgeif.__i' command too long for buffer.
compiling lwip_bridgeif_fdb.c...
Fatal error: C3907U: Via file '.\build\lwip_bridgeif_fdb.__i' command too long for buffer.
compiling lwip_checksum.c...
Fatal error: C3907U: Via file '.\build\lwip_checksum.__i' command too long for buffer.
compiling lwip_def.c...
Fatal error: C3907U: Via file '.\build\lwip_def.__i' command too long for buffer.
compiling lwip_dhcp.c...
Fatal error: C3907U: Via file '.\build\lwip_dhcp.__i' command too long for buffer.
compiling lwip_dhcp6.c...
Fatal error: C3907U: Via file '.\build\lwip_dhcp6.__i' command too long for buffer.
compiling lwip_dns.c...
Fatal error: C3907U: Via file '.\build\lwip_dns.__i' command too long for buffer.
compiling lwip_err.c...
Fatal error: C3907U: Via file '.\build\lwip_err.__i' command too long for buffer.
compiling lwip_etharp.c...
Fatal error: C3907U: Via file '.\build\lwip_etharp.__i' command too long for buffer.
compiling lwip_ethernet.c...
Fatal error: C3907U: Via file '.\build\lwip_ethernet.__i' command too long for buffer.
compiling lwip_ethip6.c...
Fatal error: C3907U: Via file '.\build\lwip_ethip6.__i' command too long for buffer.
compiling lwip_icmp.c...
Fatal error: C3907U: Via file '.\build\lwip_icmp.__i' command too long for buffer.
compiling lwip_icmp6.c...
Fatal error: C3907U: Via file '.\build\lwip_icmp6.__i' command too long for buffer.
compiling lwip_if_api.c...
Fatal error: C3907U: Via file '.\build\lwip_if_api.__i' command too long for buffer.
compiling lwip_igmp.c...
Fatal error: C3907U: Via file '.\build\lwip_igmp.__i' command too long for buffer.
compiling lwip_inet6.c...
Fatal error: C3907U: Via file '.\build\lwip_inet6.__i' command too long for buffer.
compiling lwip_inet_chksum.c...
Fatal error: C3907U: Via file '.\build\lwip_inet_chksum.__i' command too long for buffer.
compiling lwip_init.c...
Fatal error: C3907U: Via file '.\build\lwip_init.__i' command too long for buffer.
compiling lwip_ip.c...
Fatal error: C3907U: Via file '.\build\lwip_ip.__i' command too long for buffer.
compiling lwip_ip4.c...
Fatal error: C3907U: Via file '.\build\lwip_ip4.__i' command too long for buffer.
compiling lwip_ip4_addr.c...
Fatal error: C3907U: Via file '.\build\lwip_ip4_addr.__i' command too long for buffer.
compiling lwip_ip4_frag.c...
Fatal error: C3907U: Via file '.\build\lwip_ip4_frag.__i' command too long for buffer.
compiling lwip_ip6.c...
Fatal error: C3907U: Via file '.\build\lwip_ip6.__i' command too long for buffer.
compiling lwip_ip6_addr.c...
Fatal error: C3907U: Via file '.\build\lwip_ip6_addr.__i' command too long for buffer.
compiling lwip_ip6_frag.c...
Fatal error: C3907U: Via file '.\build\lwip_ip6_frag.__i' command too long for buffer.
compiling lwip_lowpan6.c...
Fatal error: C3907U: Via file '.\build\lwip_lowpan6.__i' command too long for buffer.
compiling lwip_lowpan6_ble.c...
Fatal error: C3907U: Via file '.\build\lwip_lowpan6_ble.__i' command too long for buffer.
compiling lwip_lowpan6_common.c...
Fatal error: C3907U: Via file '.\build\lwip_lowpan6_common.__i' command too long for buffer.
compiling lwip_mem.c...
Fatal error: C3907U: Via file '.\build\lwip_mem.__i' command too long for buffer.
compiling lwip_memcpy.c...
Fatal error: C3907U: Via file '.\build\lwip_memcpy.__i' command too long for buffer.
compiling lwip_memp.c...
Fatal error: C3907U: Via file '.\build\lwip_memp.__i' command too long for buffer.
compiling lwip_mld6.c...
Fatal error: C3907U: Via file '.\build\lwip_mld6.__i' command too long for buffer.
compiling lwip_nd6.c...
Fatal error: C3907U: Via file '.\build\lwip_nd6.__i' command too long for buffer.
compiling lwip_netbuf.c...
Fatal error: C3907U: Via file '.\build\lwip_netbuf.__i' command too long for buffer.
compiling lwip_netdb.c...
Fatal error: C3907U: Via file '.\build\lwip_netdb.__i' command too long for buffer.
compiling lwip_netif.c...
Fatal error: C3907U: Via file '.\build\lwip_netif.__i' command too long for buffer.
compiling lwip_netifapi.c...
Fatal error: C3907U: Via file '.\build\lwip_netifapi.__i' command too long for buffer.
compiling lwip_pbuf.c...
Fatal error: C3907U: Via file '.\build\lwip_pbuf.__i' command too long for buffer.
compiling lwip_random.c...
Fatal error: C3907U: Via file '.\build\lwip_random.__i' command too long for buffer.
compiling lwip_raw.c...
Fatal error: C3907U: Via file '.\build\lwip_raw.__i' command too long for buffer.
compiling lwip_sockets.c...
Fatal error: C3907U: Via file '.\build\lwip_sockets.__i' command too long for buffer.
compiling lwip_stats.c...
Fatal error: C3907U: Via file '.\build\lwip_stats.__i' command too long for buffer.
compiling lwip_sys.c...
Fatal error: C3907U: Via file '.\build\lwip_sys.__i' command too long for buffer.
compiling lwip_sys_arch.c...
Fatal error: C3907U: Via file '.\build\lwip_sys_arch.__i' command too long for buffer.
compiling lwip_tcp.c...
Fatal error: C3907U: Via file '.\build\lwip_tcp.__i' command too long for buffer.
compiling lwip_tcp_in.c...
Fatal error: C3907U: Via file '.\build\lwip_tcp_in.__i' command too long for buffer.
compiling lwip_tcp_isn.c...
Fatal error: C3907U: Via file '.\build\lwip_tcp_isn.__i' command too long for buffer.
compiling lwip_tcp_out.c...
Fatal error: C3907U: Via file '.\build\lwip_tcp_out.__i' command too long for buffer.
compiling lwip_tcpip.c...
Fatal error: C3907U: Via file '.\build\lwip_tcpip.__i' command too long for buffer.
compiling lwip_timeouts.c...
Fatal error: C3907U: Via file '.\build\lwip_timeouts.__i' command too long for buffer.
compiling lwip_tools.cpp...
Fatal error: C3907U: Via file '.\build\lwip_tools.__i' command too long for buffer.
compiling lwip_udp.c...
Fatal error: C3907U: Via file '.\build\lwip_udp.__i' command too long for buffer.
compiling lwip_zepif.c...
Fatal error: C3907U: Via file '.\build\lwip_zepif.__i' command too long for buffer.
compiling LWIPInterface.cpp...
Fatal error: C3907U: Via file '.\build\lwipinterface.__i' command too long for buffer.
compiling LWIPInterfaceEMAC.cpp...
Fatal error: C3907U: Via file '.\build\lwipinterfaceemac.__i' command too long for buffer.
compiling LWIPInterfaceL3IP.cpp...
Fatal error: C3907U: Via file '.\build\lwipinterfacel3ip.__i' command too long for buffer.
compiling LWIPInterfacePPP.cpp...
Fatal error: C3907U: Via file '.\build\lwipinterfaceppp.__i' command too long for buffer.
compiling LWIPMemoryManager.cpp...
Fatal error: C3907U: Via file '.\build\lwipmemorymanager.__i' command too long for buffer.
compiling LWIPStack.cpp...
Fatal error: C3907U: Via file '.\build\lwipstack.__i' command too long for buffer.
compiling mac_data_poll.c...
Fatal error: C3907U: Via file '.\build\mac_data_poll.__i' command too long for buffer.
compiling mac_fhss_callbacks.c...
Fatal error: C3907U: Via file '.\build\mac_fhss_callbacks.__i' command too long for buffer.
compiling mac_filter.c...
Fatal error: C3907U: Via file '.\build\mac_filter.__i' command too long for buffer.
compiling mac_header_helper_functions.c...
Fatal error: C3907U: Via file '.\build\mac_header_helper_functions.__i' command too long for buffer.
compiling mac_helper.c...
Fatal error: C3907U: Via file '.\build\mac_helper.__i' command too long for buffer.
compiling mac_ie_lib.c...
Fatal error: C3907U: Via file '.\build\mac_ie_lib.__i' command too long for buffer.
compiling mac_indirect_data.c...
Fatal error: C3907U: Via file '.\build\mac_indirect_data.__i' command too long for buffer.
compiling mac_mcps_sap.c...
Fatal error: C3907U: Via file '.\build\mac_mcps_sap.__i' command too long for buffer.
compiling mac_mlme.c...
Fatal error: C3907U: Via file '.\build\mac_mlme.__i' command too long for buffer.
compiling mac_neighbor_table.c...
Fatal error: C3907U: Via file '.\build\mac_neighbor_table.__i' command too long for buffer.
compiling mac_pairwise_key.c...
Fatal error: C3907U: Via file '.\build\mac_pairwise_key.__i' command too long for buffer.
compiling mac_pd_sap.c...
Fatal error: C3907U: Via file '.\build\mac_pd_sap.__i' command too long for buffer.
compiling mac_response_handler.c...
Fatal error: C3907U: Via file '.\build\mac_response_handler.__i' command too long for buffer.
compiling mac_security_mib.c...
Fatal error: C3907U: Via file '.\build\mac_security_mib.__i' command too long for buffer.
compiling mac_timer.c...
Fatal error: C3907U: Via file '.\build\mac_timer.__i' command too long for buffer.
compiling magic.c...
Fatal error: C3907U: Via file '.\build\magic.__i' command too long for buffer.
compiling mbed-utest-shim.cpp...
Fatal error: C3907U: Via file '.\build\mbed-utest-shim.__i' command too long for buffer.
compiling mbed_alloc_wrappers.cpp...
Fatal error: C3907U: Via file '.\build\mbed_alloc_wrappers.__i' command too long for buffer.
compiling mbed_application.c...
Fatal error: C3907U: Via file '.\build\mbed_application.__i' command too long for buffer.
compiling mbed_assert.c...
Fatal error: C3907U: Via file '.\build\mbed_assert.__i' command too long for buffer.
compiling mbed_atomic_impl.c...
Fatal error: C3907U: Via file '.\build\mbed_atomic_impl.__i' command too long for buffer.
compiling mbed_board.c...
Fatal error: C3907U: Via file '.\build\mbed_board.__i' command too long for buffer.
compiling mbed_boot.c...
Fatal error: C3907U: Via file '.\build\mbed_boot.__i' command too long for buffer.
compiling mbed_boot_arm_std.c...
Fatal error: C3907U: Via file '.\build\mbed_boot_arm_std.__i' command too long for buffer.
compiling mbed_crc_api.c...
Fatal error: C3907U: Via file '.\build\mbed_crc_api.__i' command too long for buffer.
compiling mbed_critical.c...
Fatal error: C3907U: Via file '.\build\mbed_critical.__i' command too long for buffer.
compiling mbed_critical_section_api.c...
Fatal error: C3907U: Via file '.\build\mbed_critical_section_api.__i' command too long for buffer.
compiling mbed_error.c...
Fatal error: C3907U: Via file '.\build\mbed_error.__i' command too long for buffer.
compiling mbed_error_hist.c...
Fatal error: C3907U: Via file '.\build\mbed_error_hist.__i' command too long for buffer.
compiling mbed_fault_handler.c...
Fatal error: C3907U: Via file '.\build\mbed_fault_handler.__i' command too long for buffer.
compiling mbed_flash_api.c...
Fatal error: C3907U: Via file '.\build\mbed_flash_api.__i' command too long for buffer.
compiling mbed_gpio.c...
Fatal error: C3907U: Via file '.\build\mbed_gpio.__i' command too long for buffer.
compiling mbed_gpio_irq.c...
Fatal error: C3907U: Via file '.\build\mbed_gpio_irq.__i' command too long for buffer.
compiling mbed_interface.c...
Fatal error: C3907U: Via file '.\build\mbed_interface.__i' command too long for buffer.
compiling mbed_itm_api.c...
Fatal error: C3907U: Via file '.\build\mbed_itm_api.__i' command too long for buffer.
compiling mbed_lp_ticker_api.c...
Fatal error: C3907U: Via file '.\build\mbed_lp_ticker_api.__i' command too long for buffer.
compiling mbed_lp_ticker_wrapper.cpp...
Fatal error: C3907U: Via file '.\build\mbed_lp_ticker_wrapper.__i' command too long for buffer.
compiling mbed_mem_trace.cpp...
Fatal error: C3907U: Via file '.\build\mbed_mem_trace.__i' command too long for buffer.
compiling mbed_mktime.c...
Fatal error: C3907U: Via file '.\build\mbed_mktime.__i' command too long for buffer.
compiling mbed_mpu_mgmt.c...
Fatal error: C3907U: Via file '.\build\mbed_mpu_mgmt.__i' command too long for buffer.
compiling mbed_mpu_v7m.c...
Fatal error: C3907U: Via file '.\build\mbed_mpu_v7m.__i' command too long for buffer.
compiling mbed_mpu_v8m.c...
Fatal error: C3907U: Via file '.\build\mbed_mpu_v8m.__i' command too long for buffer.
compiling mbed_os_timer.cpp...
Fatal error: C3907U: Via file '.\build\mbed_os_timer.__i' command too long for buffer.
compiling mbed_overrides.c...
Fatal error: C3907U: Via file '.\build\mbed_overrides.__i' command too long for buffer.
compiling mbed_pinmap_common.c...
Fatal error: C3907U: Via file '.\build\mbed_pinmap_common.__i' command too long for buffer.
compiling mbed_pinmap_default.c...
Fatal error: C3907U: Via file '.\build\mbed_pinmap_default.__i' command too long for buffer.
compiling mbed_poll.cpp...
Fatal error: C3907U: Via file '.\build\mbed_poll.__i' command too long for buffer.
compiling mbed_power_mgmt.c...
Fatal error: C3907U: Via file '.\build\mbed_power_mgmt.__i' command too long for buffer.
compiling mbed_printf_armlink_overrides.c...
Fatal error: C3907U: Via file '.\build\mbed_printf_armlink_overrides.__i' command too long for buffer.
compiling mbed_printf_implementation.c...
Fatal error: C3907U: Via file '.\build\mbed_printf_implementation.__i' command too long for buffer.
compiling mbed_printf_wrapper.c...
Fatal error: C3907U: Via file '.\build\mbed_printf_wrapper.__i' command too long for buffer.
compiling mbed_retarget.cpp...
Fatal error: C3907U: Via file '.\build\mbed_retarget.__i' command too long for buffer.
compiling mbed_rtc_time.cpp...
Fatal error: C3907U: Via file '.\build\mbed_rtc_time.__i' command too long for buffer.
compiling mbed_rtos_rtx.c...
Fatal error: C3907U: Via file '.\build\mbed_rtos_rtx.__i' command too long for buffer.
compiling mbed_rtx_handlers.c...
Fatal error: C3907U: Via file '.\build\mbed_rtx_handlers.__i' command too long for buffer.
compiling mbed_rtx_idle.cpp...
Fatal error: C3907U: Via file '.\build\mbed_rtx_idle.__i' command too long for buffer.
compiling mbed_sdk_boot.c...
Fatal error: C3907U: Via file '.\build\mbed_sdk_boot.__i' command too long for buffer.
compiling mbed_semihost_api.c...
Fatal error: C3907U: Via file '.\build\mbed_semihost_api.__i' command too long for buffer.
compiling mbed_shared_queues.cpp...
Fatal error: C3907U: Via file '.\build\mbed_shared_queues.__i' command too long for buffer.
compiling mbed_stats.c...
Fatal error: C3907U: Via file '.\build\mbed_stats.__i' command too long for buffer.
compiling mbed_thread.cpp...
Fatal error: C3907U: Via file '.\build\mbed_thread.__i' command too long for buffer.
compiling mbed_ticker_api.c...
Fatal error: C3907U: Via file '.\build\mbed_ticker_api.__i' command too long for buffer.
compiling mbed_trace.c...
Fatal error: C3907U: Via file '.\build\mbed_trace.__i' command too long for buffer.
compiling mbed_trng.cpp...
Fatal error: C3907U: Via file '.\build\mbed_trng.__i' command too long for buffer.
compiling mbed_tz_context.c...
Fatal error: C3907U: Via file '.\build\mbed_tz_context.__i' command too long for buffer.
compiling mbed_us_ticker_api.c...
Fatal error: C3907U: Via file '.\build\mbed_us_ticker_api.__i' command too long for buffer.
compiling mbed_usb_phy.cpp...
Fatal error: C3907U: Via file '.\build\mbed_usb_phy.__i' command too long for buffer.
compiling mbed_wait_api_no_rtos.c...
Fatal error: C3907U: Via file '.\build\mbed_wait_api_no_rtos.__i' command too long for buffer.
compiling mbed_wait_api_rtos.cpp...
Fatal error: C3907U: Via file '.\build\mbed_wait_api_rtos.__i' command too long for buffer.
compiling MbedCRC.cpp...
Fatal error: C3907U: Via file '.\build\mbedcrc.__i' command too long for buffer.
compiling MBRBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\mbrblockdevice.__i' command too long for buffer.
compiling MCR20Drv.c...
Fatal error: C3907U: Via file '.\build\mcr20drv.__i' command too long for buffer.
compiling md.c...
Fatal error: C3907U: Via file '.\build\md.__i' command too long for buffer.
compiling md2.c...
Fatal error: C3907U: Via file '.\build\md2.__i' command too long for buffer.
compiling md4.c...
Fatal error: C3907U: Via file '.\build\md4.__i' command too long for buffer.
compiling md5.c...
Fatal error: C3907U: Via file '.\build\md5.__i' command too long for buffer.
compiling md5_alt.c...
Fatal error: C3907U: Via file '.\build\md5_alt.__i' command too long for buffer.
compiling md_wrap.c...
Fatal error: C3907U: Via file '.\build\md_wrap.__i' command too long for buffer.
compiling memory_buffer_alloc.c...
Fatal error: C3907U: Via file '.\build\memory_buffer_alloc.__i' command too long for buffer.
compiling mesh.c...
Fatal error: C3907U: Via file '.\build\mesh.__i' command too long for buffer.
compiling mesh_system.c...
Fatal error: C3907U: Via file '.\build\mesh_system.__i' command too long for buffer.
compiling MeshInterfaceNanostack.cpp...
Fatal error: C3907U: Via file '.\build\meshinterfacenanostack.__i' command too long for buffer.
compiling MessageBuilder.cpp...
Fatal error: C3907U: Via file '.\build\messagebuilder.__i' command too long for buffer.
compiling MessageParser.cpp...
Fatal error: C3907U: Via file '.\build\messageparser.__i' command too long for buffer.
compiling Mime.cpp...
Fatal error: C3907U: Via file '.\build\mime.__i' command too long for buffer.
compiling mld.c...
Fatal error: C3907U: Via file '.\build\mld.__i' command too long for buffer.
compiling mle.c...
Fatal error: C3907U: Via file '.\build\mle.__i' command too long for buffer.
compiling mle_service.c...
Fatal error: C3907U: Via file '.\build\mle_service.__i' command too long for buffer.
compiling mle_service_buffer.c...
Fatal error: C3907U: Via file '.\build\mle_service_buffer.__i' command too long for buffer.
compiling mle_service_frame_counter_table.c...
Fatal error: C3907U: Via file '.\build\mle_service_frame_counter_table.__i' command too long for buffer.
compiling mle_service_interface.c...
Fatal error: C3907U: Via file '.\build\mle_service_interface.__i' command too long for buffer.
compiling mle_service_security.c...
Fatal error: C3907U: Via file '.\build\mle_service_security.__i' command too long for buffer.
compiling mle_tlv.c...
Fatal error: C3907U: Via file '.\build\mle_tlv.__i' command too long for buffer.
compiling mpl.c...
Fatal error: C3907U: Via file '.\build\mpl.__i' command too long for buffer.
compiling mppe.c...
Fatal error: C3907U: Via file '.\build\mppe.__i' command too long for buffer.
compiling mstd_mutex.cpp...
Fatal error: C3907U: Via file '.\build\mstd_mutex.__i' command too long for buffer.
compiling multicast_api.c...
Fatal error: C3907U: Via file '.\build\multicast_api.__i' command too long for buffer.
compiling multilink.c...
Fatal error: C3907U: Via file '.\build\multilink.__i' command too long for buffer.
compiling Mutex.cpp...
Fatal error: C3907U: Via file '.\build\mutex.__i' command too long for buffer.
compiling Nanostack.cpp...
Fatal error: C3907U: Via file '.\build\nanostack.__i' command too long for buffer.
compiling NanostackEMACInterface.cpp...
Fatal error: C3907U: Via file '.\build\nanostackemacinterface.__i' command too long for buffer.
compiling NanostackEthernetInterface.cpp...
Fatal error: C3907U: Via file '.\build\nanostackethernetinterface.__i' command too long for buffer.
compiling NanostackMemoryManager.cpp...
Fatal error: C3907U: Via file '.\build\nanostackmemorymanager.__i' command too long for buffer.
compiling NanostackPPPInterface.cpp...
Fatal error: C3907U: Via file '.\build\nanostackpppinterface.__i' command too long for buffer.
compiling NanostackRfPhyAtmel.cpp...
Fatal error: C3907U: Via file '.\build\nanostackrfphyatmel.__i' command too long for buffer.
compiling NanostackRfPhyMcr20a.cpp...
Fatal error: C3907U: Via file '.\build\nanostackrfphymcr20a.__i' command too long for buffer.
compiling NanostackRfPhys2lp.cpp...
Fatal error: C3907U: Via file '.\build\nanostackrfphys2lp.__i' command too long for buffer.
compiling nd_proxy.c...
Fatal error: C3907U: Via file '.\build\nd_proxy.__i' command too long for buffer.
compiling nd_router_object.c...
Fatal error: C3907U: Via file '.\build\nd_router_object.__i' command too long for buffer.
compiling nd_tasklet.c...
Fatal error: C3907U: Via file '.\build\nd_tasklet.__i' command too long for buffer.
compiling ndef.c...
Fatal error: C3907U: Via file '.\build\ndef.__i' command too long for buffer.
compiling neighbor_cache.c...
Fatal error: C3907U: Via file '.\build\neighbor_cache.__i' command too long for buffer.
compiling net_6lowpan_parameter_api.c...
Fatal error: C3907U: Via file '.\build\net_6lowpan_parameter_api.__i' command too long for buffer.
compiling net_ipv6.c...
Fatal error: C3907U: Via file '.\build\net_ipv6.__i' command too long for buffer.
compiling net_load_balance.c...
Fatal error: C3907U: Via file '.\build\net_load_balance.__i' command too long for buffer.
compiling net_mle.c...
Fatal error: C3907U: Via file '.\build\net_mle.__i' command too long for buffer.
compiling net_rpl.c...
Fatal error: C3907U: Via file '.\build\net_rpl.__i' command too long for buffer.
compiling net_short_address_extension.c...
Fatal error: C3907U: Via file '.\build\net_short_address_extension.__i' command too long for buffer.
compiling net_sockets.c...
Fatal error: C3907U: Via file '.\build\net_sockets.__i' command too long for buffer.
compiling net_test.c...
Fatal error: C3907U: Via file '.\build\net_test.__i' command too long for buffer.
compiling NetStackMemoryManager.cpp...
Fatal error: C3907U: Via file '.\build\netstackmemorymanager.__i' command too long for buffer.
compiling network_lib.c...
Fatal error: C3907U: Via file '.\build\network_lib.__i' command too long for buffer.
compiling NetworkInterface.cpp...
Fatal error: C3907U: Via file '.\build\networkinterface.__i' command too long for buffer.
compiling NetworkInterfaceDefaults.cpp...
Fatal error: C3907U: Via file '.\build\networkinterfacedefaults.__i' command too long for buffer.
compiling NetworkStack.cpp...
Fatal error: C3907U: Via file '.\build\networkstack.__i' command too long for buffer.
compiling nfc_scheduler.c...
Fatal error: C3907U: Via file '.\build\nfc_scheduler.__i' command too long for buffer.
compiling nfc_transport.c...
Fatal error: C3907U: Via file '.\build\nfc_transport.__i' command too long for buffer.
compiling NFCController.cpp...
Fatal error: C3907U: Via file '.\build\nfccontroller.__i' command too long for buffer.
compiling NFCControllerDriver.cpp...
Fatal error: C3907U: Via file '.\build\nfccontrollerdriver.__i' command too long for buffer.
compiling NFCEEPROM.cpp...
Fatal error: C3907U: Via file '.\build\nfceeprom.__i' command too long for buffer.
compiling NFCEEPROMDriver.cpp...
Fatal error: C3907U: Via file '.\build\nfceepromdriver.__i' command too long for buffer.
compiling NFCNDEFCapable.cpp...
Fatal error: C3907U: Via file '.\build\nfcndefcapable.__i' command too long for buffer.
compiling NFCRemoteEndpoint.cpp...
Fatal error: C3907U: Via file '.\build\nfcremoteendpoint.__i' command too long for buffer.
compiling NFCRemoteInitiator.cpp...
Fatal error: C3907U: Via file '.\build\nfcremoteinitiator.__i' command too long for buffer.
compiling NFCTarget.cpp...
Fatal error: C3907U: Via file '.\build\nfctarget.__i' command too long for buffer.
compiling nist_aes_kw.c...
Fatal error: C3907U: Via file '.\build\nist_aes_kw.__i' command too long for buffer.
compiling nist_kw.c...
Fatal error: C3907U: Via file '.\build\nist_kw.__i' command too long for buffer.
compiling ns_address_internal.c...
Fatal error: C3907U: Via file '.\build\ns_address_internal.__i' command too long for buffer.
compiling ns_cmdline.c...
Fatal error: C3907U: Via file '.\build\ns_cmdline.__i' command too long for buffer.
compiling ns_conf.c...
Fatal error: C3907U: Via file '.\build\ns_conf.__i' command too long for buffer.
compiling ns_crc.c...
Fatal error: C3907U: Via file '.\build\ns_crc.__i' command too long for buffer.
compiling ns_event_loop.c...
Fatal error: C3907U: Via file '.\build\ns_event_loop.__i' command too long for buffer.
compiling ns_event_loop_mbed.cpp...
Fatal error: C3907U: Via file '.\build\ns_event_loop_mbed.__i' command too long for buffer.
compiling ns_event_loop_mutex.c...
Fatal error: C3907U: Via file '.\build\ns_event_loop_mutex.__i' command too long for buffer.
compiling ns_file_system.c...
Fatal error: C3907U: Via file '.\build\ns_file_system.__i' command too long for buffer.
compiling ns_fnet_events.c...
Fatal error: C3907U: Via file '.\build\ns_fnet_events.__i' command too long for buffer.
compiling ns_fnet_port.c...
Fatal error: C3907U: Via file '.\build\ns_fnet_port.__i' command too long for buffer.
compiling ns_hal_init.c...
Fatal error: C3907U: Via file '.\build\ns_hal_init.__i' command too long for buffer.
compiling ns_list.c...
Fatal error: C3907U: Via file '.\build\ns_list.__i' command too long for buffer.
compiling ns_mdns_api.c...
Fatal error: C3907U: Via file '.\build\ns_mdns_api.__i' command too long for buffer.
compiling ns_monitor.c...
Fatal error: C3907U: Via file '.\build\ns_monitor.__i' command too long for buffer.
compiling ns_net.c...
Fatal error: C3907U: Via file '.\build\ns_net.__i' command too long for buffer.
compiling ns_nvm_helper.c...
Fatal error: C3907U: Via file '.\build\ns_nvm_helper.__i' command too long for buffer.
compiling ns_sha256.c...
Fatal error: C3907U: Via file '.\build\ns_sha256.__i' command too long for buffer.
compiling ns_socket.c...
Fatal error: C3907U: Via file '.\build\ns_socket.__i' command too long for buffer.
compiling ns_timeout.c...
Fatal error: C3907U: Via file '.\build\ns_timeout.__i' command too long for buffer.
compiling ns_timer.c...
Fatal error: C3907U: Via file '.\build\ns_timer.__i' command too long for buffer.
compiling nsapi_dns.cpp...
Fatal error: C3907U: Via file '.\build\nsapi_dns.__i' command too long for buffer.
compiling nsdynmemLIB.c...
Fatal error: C3907U: Via file '.\build\nsdynmemlib.__i' command too long for buffer.
compiling nvm_ram.c...
Fatal error: C3907U: Via file '.\build\nvm_ram.__i' command too long for buffer.
compiling nvstore.cpp...
Fatal error: C3907U: Via file '.\build\nvstore.__i' command too long for buffer.
compiling nwk_nvm.c...
Fatal error: C3907U: Via file '.\build\nwk_nvm.__i' command too long for buffer.
compiling ObservingBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\observingblockdevice.__i' command too long for buffer.
compiling oid.c...
Fatal error: C3907U: Via file '.\build\oid.__i' command too long for buffer.
compiling OperationListBase.cpp...
Fatal error: C3907U: Via file '.\build\operationlistbase.__i' command too long for buffer.
compiling os_systick.c...
Fatal error: C3907U: Via file '.\build\os_systick.__i' command too long for buffer.
compiling os_tick_ptim.c...
Fatal error: C3907U: Via file '.\build\os_tick_ptim.__i' command too long for buffer.
compiling padlock.c...
Fatal error: C3907U: Via file '.\build\padlock.__i' command too long for buffer.
compiling pan_blacklist.c...
Fatal error: C3907U: Via file '.\build\pan_blacklist.__i' command too long for buffer.
compiling pana.c...
Fatal error: C3907U: Via file '.\build\pana.__i' command too long for buffer.
compiling pana_avp.c...
Fatal error: C3907U: Via file '.\build\pana_avp.__i' command too long for buffer.
compiling pana_client.c...
Fatal error: C3907U: Via file '.\build\pana_client.__i' command too long for buffer.
compiling pana_eap_header.c...
Fatal error: C3907U: Via file '.\build\pana_eap_header.__i' command too long for buffer.
compiling pana_header.c...
Fatal error: C3907U: Via file '.\build\pana_header.__i' command too long for buffer.
compiling pana_relay_table.c...
Fatal error: C3907U: Via file '.\build\pana_relay_table.__i' command too long for buffer.
compiling pana_server.c...
Fatal error: C3907U: Via file '.\build\pana_server.__i' command too long for buffer.
compiling pem.c...
Fatal error: C3907U: Via file '.\build\pem.__i' command too long for buffer.
compiling PeripheralPins.c...
Fatal error: C3907U: Via file '.\build\peripheralpins.__i' command too long for buffer.
compiling pinmap.c...
Fatal error: C3907U: Via file '.\build\pinmap.__i' command too long for buffer.
compiling pk.c...
Fatal error: C3907U: Via file '.\build\pk.__i' command too long for buffer.
compiling pk_wrap.c...
Fatal error: C3907U: Via file '.\build\pk_wrap.__i' command too long for buffer.
compiling pkcs11.c...
Fatal error: C3907U: Via file '.\build\pkcs11.__i' command too long for buffer.
compiling pkcs12.c...
Fatal error: C3907U: Via file '.\build\pkcs12.__i' command too long for buffer.
compiling pkcs5.c...
Fatal error: C3907U: Via file '.\build\pkcs5.__i' command too long for buffer.
compiling pkparse.c...
Fatal error: C3907U: Via file '.\build\pkparse.__i' command too long for buffer.
compiling pkwrite.c...
Fatal error: C3907U: Via file '.\build\pkwrite.__i' command too long for buffer.
compiling platform.c...
Fatal error: C3907U: Via file '.\build\platform.__i' command too long for buffer.
compiling platform_alt.cpp...
Fatal error: C3907U: Via file '.\build\platform_alt.__i' command too long for buffer.
compiling platform_util.c...
Fatal error: C3907U: Via file '.\build\platform_util.__i' command too long for buffer.
compiling pn512.c...
Fatal error: C3907U: Via file '.\build\pn512.__i' command too long for buffer.
compiling pn512_cmd.c...
Fatal error: C3907U: Via file '.\build\pn512_cmd.__i' command too long for buffer.
compiling pn512_hw.c...
Fatal error: C3907U: Via file '.\build\pn512_hw.__i' command too long for buffer.
compiling pn512_irq.c...
Fatal error: C3907U: Via file '.\build\pn512_irq.__i' command too long for buffer.
compiling pn512_poll.c...
Fatal error: C3907U: Via file '.\build\pn512_poll.__i' command too long for buffer.
compiling pn512_registers.c...
Fatal error: C3907U: Via file '.\build\pn512_registers.__i' command too long for buffer.
compiling pn512_rf.c...
Fatal error: C3907U: Via file '.\build\pn512_rf.__i' command too long for buffer.
compiling pn512_timer.c...
Fatal error: C3907U: Via file '.\build\pn512_timer.__i' command too long for buffer.
compiling pn512_transceive.c...
Fatal error: C3907U: Via file '.\build\pn512_transceive.__i' command too long for buffer.
compiling PN512Driver.cpp...
Fatal error: C3907U: Via file '.\build\pn512driver.__i' command too long for buffer.
compiling PN512SPITransportDriver.cpp...
Fatal error: C3907U: Via file '.\build\pn512spitransportdriver.__i' command too long for buffer.
compiling PN512TransportDriver.cpp...
Fatal error: C3907U: Via file '.\build\pn512transportdriver.__i' command too long for buffer.
compiling PolledQueue.cpp...
Fatal error: C3907U: Via file '.\build\polledqueue.__i' command too long for buffer.
compiling poly1305.c...
Fatal error: C3907U: Via file '.\build\poly1305.__i' command too long for buffer.
compiling port_api.c...
Fatal error: C3907U: Via file '.\build\port_api.__i' command too long for buffer.
compiling PortIn.cpp...
Fatal error: C3907U: Via file '.\build\portin.__i' command too long for buffer.
compiling PortInOut.cpp...
Fatal error: C3907U: Via file '.\build\portinout.__i' command too long for buffer.
compiling PortOut.cpp...
Fatal error: C3907U: Via file '.\build\portout.__i' command too long for buffer.
compiling ppp.c...
Fatal error: C3907U: Via file '.\build\ppp.__i' command too long for buffer.
compiling ppp_arc4.c...
Fatal error: C3907U: Via file '.\build\ppp_arc4.__i' command too long for buffer.
compiling ppp_des.c...
Fatal error: C3907U: Via file '.\build\ppp_des.__i' command too long for buffer.
compiling ppp_ecp.c...
Fatal error: C3907U: Via file '.\build\ppp_ecp.__i' command too long for buffer.
compiling ppp_md4.c...
Fatal error: C3907U: Via file '.\build\ppp_md4.__i' command too long for buffer.
compiling ppp_md5.c...
Fatal error: C3907U: Via file '.\build\ppp_md5.__i' command too long for buffer.
compiling ppp_nsapi.cpp...
Fatal error: C3907U: Via file '.\build\ppp_nsapi.__i' command too long for buffer.
compiling ppp_service.cpp...
Fatal error: C3907U: Via file '.\build\ppp_service.__i' command too long for buffer.
compiling ppp_service_if.cpp...
Fatal error: C3907U: Via file '.\build\ppp_service_if.__i' command too long for buffer.
compiling ppp_sha1.c...
Fatal error: C3907U: Via file '.\build\ppp_sha1.__i' command too long for buffer.
compiling pppapi.c...
Fatal error: C3907U: Via file '.\build\pppapi.__i' command too long for buffer.
compiling pppcrypt.c...
Fatal error: C3907U: Via file '.\build\pppcrypt.__i' command too long for buffer.
compiling PPPInterface.cpp...
Fatal error: C3907U: Via file '.\build\pppinterface.__i' command too long for buffer.
compiling pppoe.c...
Fatal error: C3907U: Via file '.\build\pppoe.__i' command too long for buffer.
compiling pppol2tp.c...
Fatal error: C3907U: Via file '.\build\pppol2tp.__i' command too long for buffer.
compiling pppos.cpp...
Fatal error: C3907U: Via file '.\build\pppos.__i' command too long for buffer.
compiling ProfilingBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\profilingblockdevice.__i' command too long for buffer.
compiling protocol_6lowpan.c...
Fatal error: C3907U: Via file '.\build\protocol_6lowpan.__i' command too long for buffer.
compiling protocol_6lowpan_bootstrap.c...
Fatal error: C3907U: Via file '.\build\protocol_6lowpan_bootstrap.__i' command too long for buffer.
compiling protocol_6lowpan_interface.c...
Fatal error: C3907U: Via file '.\build\protocol_6lowpan_interface.__i' command too long for buffer.
compiling protocol_core.c...
Fatal error: C3907U: Via file '.\build\protocol_core.__i' command too long for buffer.
compiling protocol_core_sleep.c...
Fatal error: C3907U: Via file '.\build\protocol_core_sleep.__i' command too long for buffer.
compiling protocol_ipv6.c...
Fatal error: C3907U: Via file '.\build\protocol_ipv6.__i' command too long for buffer.
compiling protocol_stats.c...
Fatal error: C3907U: Via file '.\build\protocol_stats.__i' command too long for buffer.
compiling protocol_timer.c...
Fatal error: C3907U: Via file '.\build\protocol_timer.__i' command too long for buffer.
compiling psa_crypto.c...
Fatal error: C3907U: Via file '.\build\psa_crypto.__i' command too long for buffer.
compiling psa_crypto_se.c...
Fatal error: C3907U: Via file '.\build\psa_crypto_se.__i' command too long for buffer.
compiling psa_crypto_slot_management.c...
Fatal error: C3907U: Via file '.\build\psa_crypto_slot_management.__i' command too long for buffer.
compiling psa_crypto_storage.c...
Fatal error: C3907U: Via file '.\build\psa_crypto_storage.__i' command too long for buffer.
compiling psa_its_file.c...
Fatal error: C3907U: Via file '.\build\psa_its_file.__i' command too long for buffer.
compiling PwmOut.cpp...
Fatal error: C3907U: Via file '.\build\pwmout.__i' command too long for buffer.
compiling pwmout_api.c...
Fatal error: C3907U: Via file '.\build\pwmout_api.__i' command too long for buffer.
compiling pwmout_device.c...
Fatal error: C3907U: Via file '.\build\pwmout_device.__i' command too long for buffer.
compiling QSPI.cpp...
Fatal error: C3907U: Via file '.\build\qspi.__i' command too long for buffer.
compiling qspi_api.c...
Fatal error: C3907U: Via file '.\build\qspi_api.__i' command too long for buffer.
compiling QUECTEL_BC95.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bc95.__i' command too long for buffer.
compiling QUECTEL_BC95_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bc95_cellularcontext.__i' command too long for buffer.
compiling QUECTEL_BC95_CellularInformation.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bc95_cellularinformation.__i' command too long for buffer.
compiling QUECTEL_BC95_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bc95_cellularnetwork.__i' command too long for buffer.
compiling QUECTEL_BC95_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bc95_cellularstack.__i' command too long for buffer.
compiling QUECTEL_BG96.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96.__i' command too long for buffer.
compiling QUECTEL_BG96_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96_cellularcontext.__i' command too long for buffer.
compiling QUECTEL_BG96_CellularInformation.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96_cellularinformation.__i' command too long for buffer.
compiling QUECTEL_BG96_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96_cellularnetwork.__i' command too long for buffer.
compiling QUECTEL_BG96_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96_cellularstack.__i' command too long for buffer.
compiling QUECTEL_BG96_ControlPlane_netif.cpp...
Fatal error: C3907U: Via file '.\build\quectel_bg96_controlplane_netif.__i' command too long for buffer.
compiling QUECTEL_EC2X.cpp...
Fatal error: C3907U: Via file '.\build\quectel_ec2x.__i' command too long for buffer.
compiling QUECTEL_M26.cpp...
Fatal error: C3907U: Via file '.\build\quectel_m26.__i' command too long for buffer.
compiling QUECTEL_M26_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\quectel_m26_cellularcontext.__i' command too long for buffer.
compiling QUECTEL_M26_CellularInformation.cpp...
Fatal error: C3907U: Via file '.\build\quectel_m26_cellularinformation.__i' command too long for buffer.
compiling QUECTEL_M26_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\quectel_m26_cellularstack.__i' command too long for buffer.
compiling QUECTEL_UG96.cpp...
Fatal error: C3907U: Via file '.\build\quectel_ug96.__i' command too long for buffer.
compiling QUECTEL_UG96_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\quectel_ug96_cellularcontext.__i' command too long for buffer.
compiling randLIB.c...
Fatal error: C3907U: Via file '.\build\randlib.__i' command too long for buffer.
compiling RawSerial.cpp...
Fatal error: C3907U: Via file '.\build\rawserial.__i' command too long for buffer.
compiling ReadOnlyBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\readonlyblockdevice.__i' command too long for buffer.
compiling RecordParser.cpp...
Fatal error: C3907U: Via file '.\build\recordparser.__i' command too long for buffer.
compiling reset_reason.c...
Fatal error: C3907U: Via file '.\build\reset_reason.__i' command too long for buffer.
compiling ResetReason.cpp...
Fatal error: C3907U: Via file '.\build\resetreason.__i' command too long for buffer.
compiling rf_configuration.c...
Fatal error: C3907U: Via file '.\build\rf_configuration.__i' command too long for buffer.
compiling rf_driver_storage.c...
Fatal error: C3907U: Via file '.\build\rf_driver_storage.__i' command too long for buffer.
compiling ripemd160.c...
Fatal error: C3907U: Via file '.\build\ripemd160.__i' command too long for buffer.
compiling RM1000_AT.cpp...
Fatal error: C3907U: Via file '.\build\rm1000_at.__i' command too long for buffer.
compiling RM1000_AT_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\rm1000_at_cellularcontext.__i' command too long for buffer.
compiling RM1000_AT_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\rm1000_at_cellularnetwork.__i' command too long for buffer.
compiling RM1000_AT_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\rm1000_at_cellularstack.__i' command too long for buffer.
compiling rpl_control.c...
Fatal error: C3907U: Via file '.\build\rpl_control.__i' command too long for buffer.
compiling rpl_data.c...
Fatal error: C3907U: Via file '.\build\rpl_data.__i' command too long for buffer.
compiling rpl_downward.c...
Fatal error: C3907U: Via file '.\build\rpl_downward.__i' command too long for buffer.
compiling rpl_mrhof.c...
Fatal error: C3907U: Via file '.\build\rpl_mrhof.__i' command too long for buffer.
compiling rpl_objective.c...
Fatal error: C3907U: Via file '.\build\rpl_objective.__i' command too long for buffer.
compiling rpl_of0.c...
Fatal error: C3907U: Via file '.\build\rpl_of0.__i' command too long for buffer.
compiling rpl_policy.c...
Fatal error: C3907U: Via file '.\build\rpl_policy.__i' command too long for buffer.
compiling rpl_upward.c...
Fatal error: C3907U: Via file '.\build\rpl_upward.__i' command too long for buffer.
compiling rsa.c...
Fatal error: C3907U: Via file '.\build\rsa.__i' command too long for buffer.
compiling rsa_internal.c...
Fatal error: C3907U: Via file '.\build\rsa_internal.__i' command too long for buffer.
compiling rtc_api.c...
Fatal error: C3907U: Via file '.\build\rtc_api.__i' command too long for buffer.
compiling RtosTimer.cpp...
Fatal error: C3907U: Via file '.\build\rtostimer.__i' command too long for buffer.
compiling RTX_Config.c...
Fatal error: C3907U: Via file '.\build\rtx_config.__i' command too long for buffer.
compiling rtx_delay.c...
Fatal error: C3907U: Via file '.\build\rtx_delay.__i' command too long for buffer.
compiling rtx_evflags.c...
Fatal error: C3907U: Via file '.\build\rtx_evflags.__i' command too long for buffer.
compiling rtx_evr.c...
Fatal error: C3907U: Via file '.\build\rtx_evr.__i' command too long for buffer.
compiling rtx_kernel.c...
Fatal error: C3907U: Via file '.\build\rtx_kernel.__i' command too long for buffer.
compiling rtx_lib.c...
Fatal error: C3907U: Via file '.\build\rtx_lib.__i' command too long for buffer.
compiling rtx_memory.c...
Fatal error: C3907U: Via file '.\build\rtx_memory.__i' command too long for buffer.
compiling rtx_mempool.c...
Fatal error: C3907U: Via file '.\build\rtx_mempool.__i' command too long for buffer.
compiling rtx_msgqueue.c...
Fatal error: C3907U: Via file '.\build\rtx_msgqueue.__i' command too long for buffer.
compiling rtx_mutex.c...
Fatal error: C3907U: Via file '.\build\rtx_mutex.__i' command too long for buffer.
compiling rtx_semaphore.c...
Fatal error: C3907U: Via file '.\build\rtx_semaphore.__i' command too long for buffer.
compiling rtx_system.c...
Fatal error: C3907U: Via file '.\build\rtx_system.__i' command too long for buffer.
compiling rtx_thread.c...
Fatal error: C3907U: Via file '.\build\rtx_thread.__i' command too long for buffer.
compiling rtx_timer.c...
Fatal error: C3907U: Via file '.\build\rtx_timer.__i' command too long for buffer.
compiling SARA4_PPP.cpp...
Fatal error: C3907U: Via file '.\build\sara4_ppp.__i' command too long for buffer.
compiling SARA4_PPP_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\sara4_ppp_cellularnetwork.__i' command too long for buffer.
compiling sec_prot_certs.c...
Fatal error: C3907U: Via file '.\build\sec_prot_certs.__i' command too long for buffer.
compiling sec_prot_keys.c...
Fatal error: C3907U: Via file '.\build\sec_prot_keys.__i' command too long for buffer.
compiling sec_prot_lib.c...
Fatal error: C3907U: Via file '.\build\sec_prot_lib.__i' command too long for buffer.
compiling SecureStore.cpp...
Fatal error: C3907U: Via file '.\build\securestore.__i' command too long for buffer.
compiling security_lib.c...
Fatal error: C3907U: Via file '.\build\security_lib.__i' command too long for buffer.
compiling Semaphore.cpp...
Fatal error: C3907U: Via file '.\build\semaphore.__i' command too long for buffer.
compiling Serial.cpp...
Fatal error: C3907U: Via file '.\build\serial.__i' command too long for buffer.
compiling serial_api.c...
Fatal error: C3907U: Via file '.\build\serial_api.__i' command too long for buffer.
compiling serial_device.c...
Fatal error: C3907U: Via file '.\build\serial_device.__i' command too long for buffer.
compiling serial_mac_api.c...
Fatal error: C3907U: Via file '.\build\serial_mac_api.__i' command too long for buffer.
compiling SerialBase.cpp...
Fatal error: C3907U: Via file '.\build\serialbase.__i' command too long for buffer.
compiling SerialWireOutput.cpp...
Fatal error: C3907U: Via file '.\build\serialwireoutput.__i' command too long for buffer.
compiling sha1.c...
Fatal error: C3907U: Via file '.\build\sha1.__i' command too long for buffer.
compiling sha1_alt.c...
Fatal error: C3907U: Via file '.\build\sha1_alt.__i' command too long for buffer.
compiling sha256.c...
Fatal error: C3907U: Via file '.\build\sha256.__i' command too long for buffer.
compiling sha256_alt.c...
Fatal error: C3907U: Via file '.\build\sha256_alt.__i' command too long for buffer.
compiling sha512.c...
Fatal error: C3907U: Via file '.\build\sha512.__i' command too long for buffer.
compiling shalib.c...
Fatal error: C3907U: Via file '.\build\shalib.__i' command too long for buffer.
compiling SimpleMessageParser.cpp...
Fatal error: C3907U: Via file '.\build\simplemessageparser.__i' command too long for buffer.
compiling sleep.c...
Fatal error: C3907U: Via file '.\build\sleep.__i' command too long for buffer.
compiling SlicingBlockDevice.cpp...
Fatal error: C3907U: Via file '.\build\slicingblockdevice.__i' command too long for buffer.
compiling sn_coap_builder.c...
Fatal error: C3907U: Via file '.\build\sn_coap_builder.__i' command too long for buffer.
compiling sn_coap_header_check.c...
Fatal error: C3907U: Via file '.\build\sn_coap_header_check.__i' command too long for buffer.
compiling sn_coap_parser.c...
Fatal error: C3907U: Via file '.\build\sn_coap_parser.__i' command too long for buffer.
compiling sn_coap_protocol.c...
Fatal error: C3907U: Via file '.\build\sn_coap_protocol.__i' command too long for buffer.
compiling sockbuf.c...
Fatal error: C3907U: Via file '.\build\sockbuf.__i' command too long for buffer.
compiling socket_api.c...
Fatal error: C3907U: Via file '.\build\socket_api.__i' command too long for buffer.
compiling SocketAddress.cpp...
Fatal error: C3907U: Via file '.\build\socketaddress.__i' command too long for buffer.
compiling SocketStats.cpp...
Fatal error: C3907U: Via file '.\build\socketstats.__i' command too long for buffer.
compiling SPI.cpp...
Fatal error: C3907U: Via file '.\build\spi.__i' command too long for buffer.
compiling spi_api.c...
Fatal error: C3907U: Via file '.\build\spi_api.__i' command too long for buffer.
compiling SPISlave.cpp...
Fatal error: C3907U: Via file '.\build\spislave.__i' command too long for buffer.
compiling ssl_cache.c...
Fatal error: C3907U: Via file '.\build\ssl_cache.__i' command too long for buffer.
compiling ssl_ciphersuites.c...
Fatal error: C3907U: Via file '.\build\ssl_ciphersuites.__i' command too long for buffer.
compiling ssl_cli.c...
Fatal error: C3907U: Via file '.\build\ssl_cli.__i' command too long for buffer.
compiling ssl_cookie.c...
Fatal error: C3907U: Via file '.\build\ssl_cookie.__i' command too long for buffer.
compiling ssl_srv.c...
Fatal error: C3907U: Via file '.\build\ssl_srv.__i' command too long for buffer.
compiling ssl_ticket.c...
Fatal error: C3907U: Via file '.\build\ssl_ticket.__i' command too long for buffer.
compiling ssl_tls.c...
Fatal error: C3907U: Via file '.\build\ssl_tls.__i' command too long for buffer.
compiling stm32f0xx_hal.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal.__i' command too long for buffer.
compiling stm32f0xx_hal_adc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_adc.__i' command too long for buffer.
compiling stm32f0xx_hal_adc_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_adc_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_can.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_can.__i' command too long for buffer.
compiling stm32f0xx_hal_cec.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_cec.__i' command too long for buffer.
compiling stm32f0xx_hal_comp.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_comp.__i' command too long for buffer.
compiling stm32f0xx_hal_cortex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_cortex.__i' command too long for buffer.
compiling stm32f0xx_hal_crc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_crc.__i' command too long for buffer.
compiling stm32f0xx_hal_crc_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_crc_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_dac.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_dac.__i' command too long for buffer.
compiling stm32f0xx_hal_dac_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_dac_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_dma.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_dma.__i' command too long for buffer.
compiling stm32f0xx_hal_flash.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_flash.__i' command too long for buffer.
compiling stm32f0xx_hal_flash_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_flash_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_gpio.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_gpio.__i' command too long for buffer.
compiling stm32f0xx_hal_i2c.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_i2c.__i' command too long for buffer.
compiling stm32f0xx_hal_i2c_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_i2c_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_i2s.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_i2s.__i' command too long for buffer.
compiling stm32f0xx_hal_irda.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_irda.__i' command too long for buffer.
compiling stm32f0xx_hal_iwdg.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_iwdg.__i' command too long for buffer.
compiling stm32f0xx_hal_pcd.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_pcd.__i' command too long for buffer.
compiling stm32f0xx_hal_pcd_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_pcd_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_pwr.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_pwr.__i' command too long for buffer.
compiling stm32f0xx_hal_pwr_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_pwr_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_rcc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_rcc.__i' command too long for buffer.
compiling stm32f0xx_hal_rcc_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_rcc_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_rtc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_rtc.__i' command too long for buffer.
compiling stm32f0xx_hal_rtc_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_rtc_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_smartcard.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_smartcard.__i' command too long for buffer.
compiling stm32f0xx_hal_smartcard_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_smartcard_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_smbus.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_smbus.__i' command too long for buffer.
compiling stm32f0xx_hal_spi.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_spi.__i' command too long for buffer.
compiling stm32f0xx_hal_spi_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_spi_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_tim.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_tim.__i' command too long for buffer.
compiling stm32f0xx_hal_tim_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_tim_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_tsc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_tsc.__i' command too long for buffer.
compiling stm32f0xx_hal_uart.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_uart.__i' command too long for buffer.
compiling stm32f0xx_hal_uart_ex.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_uart_ex.__i' command too long for buffer.
compiling stm32f0xx_hal_usart.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_usart.__i' command too long for buffer.
compiling stm32f0xx_hal_wwdg.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_hal_wwdg.__i' command too long for buffer.
compiling stm32f0xx_ll_adc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_adc.__i' command too long for buffer.
compiling stm32f0xx_ll_comp.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_comp.__i' command too long for buffer.
compiling stm32f0xx_ll_crc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_crc.__i' command too long for buffer.
compiling stm32f0xx_ll_crs.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_crs.__i' command too long for buffer.
compiling stm32f0xx_ll_dac.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_dac.__i' command too long for buffer.
compiling stm32f0xx_ll_dma.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_dma.__i' command too long for buffer.
compiling stm32f0xx_ll_exti.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_exti.__i' command too long for buffer.
compiling stm32f0xx_ll_gpio.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_gpio.__i' command too long for buffer.
compiling stm32f0xx_ll_i2c.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_i2c.__i' command too long for buffer.
compiling stm32f0xx_ll_pwr.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_pwr.__i' command too long for buffer.
compiling stm32f0xx_ll_rcc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_rcc.__i' command too long for buffer.
compiling stm32f0xx_ll_rtc.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_rtc.__i' command too long for buffer.
compiling stm32f0xx_ll_spi.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_spi.__i' command too long for buffer.
compiling stm32f0xx_ll_tim.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_tim.__i' command too long for buffer.
compiling stm32f0xx_ll_usart.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_usart.__i' command too long for buffer.
compiling stm32f0xx_ll_utils.c...
Fatal error: C3907U: Via file '.\build\stm32f0xx_ll_utils.__i' command too long for buffer.
compiling stm_spi_api.c...
Fatal error: C3907U: Via file '.\build\stm_spi_api.__i' command too long for buffer.
compiling stoip4.c...
Fatal error: C3907U: Via file '.\build\stoip4.__i' command too long for buffer.
compiling stoip6.c...
Fatal error: C3907U: Via file '.\build\stoip6.__i' command too long for buffer.
compiling Stream.cpp...
Fatal error: C3907U: Via file '.\build\stream.__i' command too long for buffer.
compiling supp_eap_tls_sec_prot.c...
Fatal error: C3907U: Via file '.\build\supp_eap_tls_sec_prot.__i' command too long for buffer.
compiling supp_fwh_sec_prot.c...
Fatal error: C3907U: Via file '.\build\supp_fwh_sec_prot.__i' command too long for buffer.
compiling supp_gkh_sec_prot.c...
Fatal error: C3907U: Via file '.\build\supp_gkh_sec_prot.__i' command too long for buffer.
compiling sw_mac.c...
Fatal error: C3907U: Via file '.\build\sw_mac.__i' command too long for buffer.
compiling system_clock.c...
Fatal error: C3907U: Via file '.\build\system_clock.__i' command too long for buffer.
compiling system_stm32f0xx.c...
Fatal error: C3907U: Via file '.\build\system_stm32f0xx.__i' command too long for buffer.
compiling system_timer.c...
Fatal error: C3907U: Via file '.\build\system_timer.__i' command too long for buffer.
compiling SystemStorage.cpp...
Fatal error: C3907U: Via file '.\build\systemstorage.__i' command too long for buffer.
compiling SysTimer.cpp...
Fatal error: C3907U: Via file '.\build\systimer.__i' command too long for buffer.
compiling TableCRC.cpp...
Fatal error: C3907U: Via file '.\build\tablecrc.__i' command too long for buffer.
compiling TaskBase.cpp...
Fatal error: C3907U: Via file '.\build\taskbase.__i' command too long for buffer.
compiling tcp.c...
Fatal error: C3907U: Via file '.\build\tcp.__i' command too long for buffer.
compiling TCPServer.cpp...
Fatal error: C3907U: Via file '.\build\tcpserver.__i' command too long for buffer.
compiling TCPSocket.cpp...
Fatal error: C3907U: Via file '.\build\tcpsocket.__i' command too long for buffer.
compiling TDBStore.cpp...
Fatal error: C3907U: Via file '.\build\tdbstore.__i' command too long for buffer.
compiling TELIT_HE910.cpp...
Fatal error: C3907U: Via file '.\build\telit_he910.__i' command too long for buffer.
compiling TELIT_ME910.cpp...
Fatal error: C3907U: Via file '.\build\telit_me910.__i' command too long for buffer.
compiling TELIT_ME910_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\telit_me910_cellularcontext.__i' command too long for buffer.
compiling Text.cpp...
Fatal error: C3907U: Via file '.\build\text.__i' command too long for buffer.
compiling ThisThread.cpp...
Fatal error: C3907U: Via file '.\build\thisthread.__i' command too long for buffer.
compiling Thread.cpp...
Fatal error: C3907U: Via file '.\build\thread.__i' command too long for buffer.
compiling thread_bbr_api.c...
Fatal error: C3907U: Via file '.\build\thread_bbr_api.__i' command too long for buffer.
compiling thread_bbr_commercial.c...
Fatal error: C3907U: Via file '.\build\thread_bbr_commercial.__i' command too long for buffer.
compiling thread_beacon.c...
Fatal error: C3907U: Via file '.\build\thread_beacon.__i' command too long for buffer.
compiling thread_bootstrap.c...
Fatal error: C3907U: Via file '.\build\thread_bootstrap.__i' command too long for buffer.
compiling thread_border_router_api.c...
Fatal error: C3907U: Via file '.\build\thread_border_router_api.__i' command too long for buffer.
compiling thread_ccm.c...
Fatal error: C3907U: Via file '.\build\thread_ccm.__i' command too long for buffer.
compiling thread_commissioning_api.c...
Fatal error: C3907U: Via file '.\build\thread_commissioning_api.__i' command too long for buffer.
compiling thread_commissioning_if.c...
Fatal error: C3907U: Via file '.\build\thread_commissioning_if.__i' command too long for buffer.
compiling thread_common.c...
Fatal error: C3907U: Via file '.\build\thread_common.__i' command too long for buffer.
compiling thread_dhcpv6_server.c...
Fatal error: C3907U: Via file '.\build\thread_dhcpv6_server.__i' command too long for buffer.
compiling thread_diagnostic.c...
Fatal error: C3907U: Via file '.\build\thread_diagnostic.__i' command too long for buffer.
compiling thread_discovery.c...
Fatal error: C3907U: Via file '.\build\thread_discovery.__i' command too long for buffer.
compiling thread_host_bootstrap.c...
Fatal error: C3907U: Via file '.\build\thread_host_bootstrap.__i' command too long for buffer.
compiling thread_joiner_application.c...
Fatal error: C3907U: Via file '.\build\thread_joiner_application.__i' command too long for buffer.
compiling thread_leader_service.c...
Fatal error: C3907U: Via file '.\build\thread_leader_service.__i' command too long for buffer.
compiling thread_lowpower_api.c...
Fatal error: C3907U: Via file '.\build\thread_lowpower_api.__i' command too long for buffer.
compiling thread_lowpower_private_api.c...
Fatal error: C3907U: Via file '.\build\thread_lowpower_private_api.__i' command too long for buffer.
compiling thread_management_api.c...
Fatal error: C3907U: Via file '.\build\thread_management_api.__i' command too long for buffer.
compiling thread_management_client.c...
Fatal error: C3907U: Via file '.\build\thread_management_client.__i' command too long for buffer.
compiling thread_management_if.c...
Fatal error: C3907U: Via file '.\build\thread_management_if.__i' command too long for buffer.
compiling thread_management_server.c...
Fatal error: C3907U: Via file '.\build\thread_management_server.__i' command too long for buffer.
compiling thread_mdns.c...
Fatal error: C3907U: Via file '.\build\thread_mdns.__i' command too long for buffer.
compiling thread_meshcop_lib.c...
Fatal error: C3907U: Via file '.\build\thread_meshcop_lib.__i' command too long for buffer.
compiling thread_mle_message_handler.c...
Fatal error: C3907U: Via file '.\build\thread_mle_message_handler.__i' command too long for buffer.
compiling thread_nd.c...
Fatal error: C3907U: Via file '.\build\thread_nd.__i' command too long for buffer.
compiling thread_neighbor_class.c...
Fatal error: C3907U: Via file '.\build\thread_neighbor_class.__i' command too long for buffer.
compiling thread_net_config_api.c...
Fatal error: C3907U: Via file '.\build\thread_net_config_api.__i' command too long for buffer.
compiling thread_network_data_lib.c...
Fatal error: C3907U: Via file '.\build\thread_network_data_lib.__i' command too long for buffer.
compiling thread_network_data_storage.c...
Fatal error: C3907U: Via file '.\build\thread_network_data_storage.__i' command too long for buffer.
compiling thread_network_synch.c...
Fatal error: C3907U: Via file '.\build\thread_network_synch.__i' command too long for buffer.
compiling thread_nvm_store.c...
Fatal error: C3907U: Via file '.\build\thread_nvm_store.__i' command too long for buffer.
compiling thread_resolution_client.c...
Fatal error: C3907U: Via file '.\build\thread_resolution_client.__i' command too long for buffer.
compiling thread_resolution_server.c...
Fatal error: C3907U: Via file '.\build\thread_resolution_server.__i' command too long for buffer.
compiling thread_router_bootstrap.c...
Fatal error: C3907U: Via file '.\build\thread_router_bootstrap.__i' command too long for buffer.
compiling thread_routing.c...
Fatal error: C3907U: Via file '.\build\thread_routing.__i' command too long for buffer.
compiling thread_tasklet.c...
Fatal error: C3907U: Via file '.\build\thread_tasklet.__i' command too long for buffer.
compiling thread_test_api.c...
Fatal error: C3907U: Via file '.\build\thread_test_api.__i' command too long for buffer.
compiling threading.c...
Fatal error: C3907U: Via file '.\build\threading.__i' command too long for buffer.
compiling ThreadInterface.cpp...
Fatal error: C3907U: Via file '.\build\threadinterface.__i' command too long for buffer.
compiling Ticker.cpp...
Fatal error: C3907U: Via file '.\build\ticker.__i' command too long for buffer.
compiling Timeout.cpp...
Fatal error: C3907U: Via file '.\build\timeout.__i' command too long for buffer.
compiling Timer.cpp...
Fatal error: C3907U: Via file '.\build\timer.__i' command too long for buffer.
compiling TimerEvent.cpp...
Fatal error: C3907U: Via file '.\build\timerevent.__i' command too long for buffer.
compiling timing.c...
Fatal error: C3907U: Via file '.\build\timing.__i' command too long for buffer.
compiling tls_ccm_crypt.c...
Fatal error: C3907U: Via file '.\build\tls_ccm_crypt.__i' command too long for buffer.
compiling tls_lib.c...
Fatal error: C3907U: Via file '.\build\tls_lib.__i' command too long for buffer.
compiling tls_sec_prot.c...
Fatal error: C3907U: Via file '.\build\tls_sec_prot.__i' command too long for buffer.
compiling tls_sec_prot_lib.c...
Fatal error: C3907U: Via file '.\build\tls_sec_prot_lib.__i' command too long for buffer.
compiling TLSSocket.cpp...
Fatal error: C3907U: Via file '.\build\tlssocket.__i' command too long for buffer.
compiling TLSSocketWrapper.cpp...
Fatal error: C3907U: Via file '.\build\tlssocketwrapper.__i' command too long for buffer.
compiling transceiver.c...
Fatal error: C3907U: Via file '.\build\transceiver.__i' command too long for buffer.
compiling trickle.c...
Fatal error: C3907U: Via file '.\build\trickle.__i' command too long for buffer.
compiling trng_api.c...
Fatal error: C3907U: Via file '.\build\trng_api.__i' command too long for buffer.
compiling type4_target.c...
Fatal error: C3907U: Via file '.\build\type4_target.__i' command too long for buffer.
compiling Type4RemoteInitiator.cpp...
Fatal error: C3907U: Via file '.\build\type4remoteinitiator.__i' command too long for buffer.
compiling UARTSerial.cpp...
Fatal error: C3907U: Via file '.\build\uartserial.__i' command too long for buffer.
compiling UBLOX_AT.cpp...
Fatal error: C3907U: Via file '.\build\ublox_at.__i' command too long for buffer.
compiling UBLOX_AT_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\ublox_at_cellularcontext.__i' command too long for buffer.
compiling UBLOX_AT_CellularNetwork.cpp...
Fatal error: C3907U: Via file '.\build\ublox_at_cellularnetwork.__i' command too long for buffer.
compiling UBLOX_AT_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\ublox_at_cellularstack.__i' command too long for buffer.
compiling UBLOX_N2XX.cpp...
Fatal error: C3907U: Via file '.\build\ublox_n2xx.__i' command too long for buffer.
compiling UBLOX_N2XX_CellularContext.cpp...
Fatal error: C3907U: Via file '.\build\ublox_n2xx_cellularcontext.__i' command too long for buffer.
compiling UBLOX_N2XX_CellularSMS.cpp...
Fatal error: C3907U: Via file '.\build\ublox_n2xx_cellularsms.__i' command too long for buffer.
compiling UBLOX_N2XX_CellularStack.cpp...
Fatal error: C3907U: Via file '.\build\ublox_n2xx_cellularstack.__i' command too long for buffer.
compiling UBLOX_PPP.cpp...
Fatal error: C3907U: Via file '.\build\ublox_ppp.__i' command too long for buffer.
compiling udp.c...
Fatal error: C3907U: Via file '.\build\udp.__i' command too long for buffer.
compiling UDPSocket.cpp...
Fatal error: C3907U: Via file '.\build\udpsocket.__i' command too long for buffer.
compiling unity.c...
Fatal error: C3907U: Via file '.\build\unity.__i' command too long for buffer.
compiling unity_handler.cpp...
Fatal error: C3907U: Via file '.\build\unity_handler.__i' command too long for buffer.
compiling upap.c...
Fatal error: C3907U: Via file '.\build\upap.__i' command too long for buffer.
compiling URI.cpp...
Fatal error: C3907U: Via file '.\build\uri.__i' command too long for buffer.
compiling us_ticker.c...
Fatal error: C3907U: Via file '.\build\us_ticker.__i' command too long for buffer.
compiling USBAudio.cpp...
Fatal error: C3907U: Via file '.\build\usbaudio.__i' command too long for buffer.
compiling USBCDC.cpp...
Fatal error: C3907U: Via file '.\build\usbcdc.__i' command too long for buffer.
compiling USBCDC_ECM.cpp...
Fatal error: C3907U: Via file '.\build\usbcdc_ecm.__i' command too long for buffer.
compiling USBDevice.cpp...
Fatal error: C3907U: Via file '.\build\usbdevice.__i' command too long for buffer.
compiling USBHID.cpp...
Fatal error: C3907U: Via file '.\build\usbhid.__i' command too long for buffer.
compiling USBKeyboard.cpp...
Fatal error: C3907U: Via file '.\build\usbkeyboard.__i' command too long for buffer.
compiling USBMIDI.cpp...
Fatal error: C3907U: Via file '.\build\usbmidi.__i' command too long for buffer.
compiling USBMouse.cpp...
Fatal error: C3907U: Via file '.\build\usbmouse.__i' command too long for buffer.
compiling USBMouseKeyboard.cpp...
Fatal error: C3907U: Via file '.\build\usbmousekeyboard.__i' command too long for buffer.
compiling USBMSD.cpp...
Fatal error: C3907U: Via file '.\build\usbmsd.__i' command too long for buffer.
compiling USBPhy_STM32.cpp...
Fatal error: C3907U: Via file '.\build\usbphy_stm32.__i' command too long for buffer.
compiling USBSerial.cpp...
Fatal error: C3907U: Via file '.\build\usbserial.__i' command too long for buffer.
compiling utest_case.cpp...
Fatal error: C3907U: Via file '.\build\utest_case.__i' command too long for buffer.
compiling utest_default_handlers.cpp...
Fatal error: C3907U: Via file '.\build\utest_default_handlers.__i' command too long for buffer.
compiling utest_greentea_handlers.cpp...
Fatal error: C3907U: Via file '.\build\utest_greentea_handlers.__i' command too long for buffer.
compiling utest_harness.cpp...
Fatal error: C3907U: Via file '.\build\utest_harness.__i' command too long for buffer.
compiling utest_shim.cpp...
Fatal error: C3907U: Via file '.\build\utest_shim.__i' command too long for buffer.
compiling utest_stack_trace.cpp...
Fatal error: C3907U: Via file '.\build\utest_stack_trace.__i' command too long for buffer.
compiling utest_types.cpp...
Fatal error: C3907U: Via file '.\build\utest_types.__i' command too long for buffer.
compiling util.cpp...
Fatal error: C3907U: Via file '.\build\util.__i' command too long for buffer.
compiling utils.c...
Fatal error: C3907U: Via file '.\build\utils.__i' command too long for buffer.
compiling version.c...
Fatal error: C3907U: Via file '.\build\version.__i' command too long for buffer.
compiling version_features.c...
Fatal error: C3907U: Via file '.\build\version_features.__i' command too long for buffer.
compiling virtual_rf_client.c...
Fatal error: C3907U: Via file '.\build\virtual_rf_client.__i' command too long for buffer.
compiling virtual_rf_driver.c...
Fatal error: C3907U: Via file '.\build\virtual_rf_driver.__i' command too long for buffer.
compiling vj.c...
Fatal error: C3907U: Via file '.\build\vj.__i' command too long for buffer.
compiling Watchdog.cpp...
Fatal error: C3907U: Via file '.\build\watchdog.__i' command too long for buffer.
compiling watchdog_api.c...
Fatal error: C3907U: Via file '.\build\watchdog_api.__i' command too long for buffer.
compiling whiteboard.c...
Fatal error: C3907U: Via file '.\build\whiteboard.__i' command too long for buffer.
compiling WiFiAccessPoint.cpp...
Fatal error: C3907U: Via file '.\build\wifiaccesspoint.__i' command too long for buffer.
compiling wisun_tasklet.c...
Fatal error: C3907U: Via file '.\build\wisun_tasklet.__i' command too long for buffer.
compiling WisunInterface.cpp...
Fatal error: C3907U: Via file '.\build\wisuninterface.__i' command too long for buffer.
compiling ws_bbr_api.c...
Fatal error: C3907U: Via file '.\build\ws_bbr_api.__i' command too long for buffer.
compiling ws_bootstrap.c...
Fatal error: C3907U: Via file '.\build\ws_bootstrap.__i' command too long for buffer.
compiling ws_common.c...
Fatal error: C3907U: Via file '.\build\ws_common.__i' command too long for buffer.
compiling ws_eapol_auth_relay.c...
Fatal error: C3907U: Via file '.\build\ws_eapol_auth_relay.__i' command too long for buffer.
compiling ws_eapol_pdu.c...
Fatal error: C3907U: Via file '.\build\ws_eapol_pdu.__i' command too long for buffer.
compiling ws_eapol_relay.c...
Fatal error: C3907U: Via file '.\build\ws_eapol_relay.__i' command too long for buffer.
compiling ws_eapol_relay_lib.c...
Fatal error: C3907U: Via file '.\build\ws_eapol_relay_lib.__i' command too long for buffer.
compiling ws_empty_functions.c...
Fatal error: C3907U: Via file '.\build\ws_empty_functions.__i' command too long for buffer.
compiling ws_ie_lib.c...
Fatal error: C3907U: Via file '.\build\ws_ie_lib.__i' command too long for buffer.
compiling ws_llc_data_service.c...
Fatal error: C3907U: Via file '.\build\ws_llc_data_service.__i' command too long for buffer.
compiling ws_management_api.c...
Fatal error: C3907U: Via file '.\build\ws_management_api.__i' command too long for buffer.
compiling ws_mpx_header.c...
Fatal error: C3907U: Via file '.\build\ws_mpx_header.__i' command too long for buffer.
compiling ws_neighbor_class.c...
Fatal error: C3907U: Via file '.\build\ws_neighbor_class.__i' command too long for buffer.
compiling ws_pae_auth.c...
Fatal error: C3907U: Via file '.\build\ws_pae_auth.__i' command too long for buffer.
compiling ws_pae_controller.c...
Fatal error: C3907U: Via file '.\build\ws_pae_controller.__i' command too long for buffer.
compiling ws_pae_lib.c...
Fatal error: C3907U: Via file '.\build\ws_pae_lib.__i' command too long for buffer.
compiling ws_pae_nvm_data.c...
Fatal error: C3907U: Via file '.\build\ws_pae_nvm_data.__i' command too long for buffer.
compiling ws_pae_nvm_store.c...
Fatal error: C3907U: Via file '.\build\ws_pae_nvm_store.__i' command too long for buffer.
compiling ws_pae_supp.c...
Fatal error: C3907U: Via file '.\build\ws_pae_supp.__i' command too long for buffer.
compiling ws_pae_timers.c...
Fatal error: C3907U: Via file '.\build\ws_pae_timers.__i' command too long for buffer.
compiling ws_stats.c...
Fatal error: C3907U: Via file '.\build\ws_stats.__i' command too long for buffer.
compiling ws_test_api.c...
Fatal error: C3907U: Via file '.\build\ws_test_api.__i' command too long for buffer.
compiling x509.c...
Fatal error: C3907U: Via file '.\build\x509.__i' command too long for buffer.
compiling x509_create.c...
Fatal error: C3907U: Via file '.\build\x509_create.__i' command too long for buffer.
compiling x509_crl.c...
Fatal error: C3907U: Via file '.\build\x509_crl.__i' command too long for buffer.
compiling x509_crt.c...
Fatal error: C3907U: Via file '.\build\x509_crt.__i' command too long for buffer.
compiling x509_csr.c...
Fatal error: C3907U: Via file '.\build\x509_csr.__i' command too long for buffer.
compiling x509write_crt.c...
Fatal error: C3907U: Via file '.\build\x509write_crt.__i' command too long for buffer.
compiling x509write_csr.c...
Fatal error: C3907U: Via file '.\build\x509write_csr.__i' command too long for buffer.
compiling xtea.c...
Fatal error: C3907U: Via file '.\build\xtea.__i' command too long for buffer.
compiling main.cpp...
Fatal error: C3907U: Via file '.\build\main.__i' command too long for buffer.
linking...
.\BUILD\mbed-os-example-blinky.axf: error: L6002U: Could not open file .\build\6lowpan_iphc.o: No such file or directory
Finished: 0 information, 0 warning, 0 error and 1 fatal error messages.
".\BUILD\mbed-os-example-blinky.axf" - 1 Error(s), 0 Warning(s).
Target not created.
123
STM32团队
最新内容
