无刷直流电机不转
好久啊 提问时间:2015-7-9 10:12 /
收藏 评论12 发布时间:2015-7-9 10:12
12个回答
那就地方iv 回答时间:2015-7-14 11:02:48
好久啊 发表于 2015-7-14 09:58
暂时还用不到电调
电调就是控制无刷电机的,你现在做的控制板跟电调的功能是一样的
星辰一方 回答时间:2015-7-14 11:09:47
暂时还用不到电调
不用电调怎么驱动呢?
好久啊 回答时间:2015-7-14 11:14:10
  1. #include "hall.h"
  2. unsigned char bHallStartStep;//换相步序变量定义
  3. //换相步序值0-5分别对应AB\AC\BC\BA\CA\CB
  4. unsigned int OutPwmValue=0;//PWM输出值变量定义
  5. unsigned char bHallSteps[2][8]={
  6. {7,5,3,4,1,0,2,7},//正转
  7. {7,2,0,1,4,3,5,7}//反转
  8. };
  9. const unsigned char PWM_EN1_TAB[6]={0x01,0x01,0x10,0x10,0x00,0x00};
  10. //六步法中,CH1\CH2通道极性及使能配置
  11. const unsigned char PWM_EN2_TAB[6]={0x0,0x00,0x00,0x0,0x1,0x1};
  12. //六步法中,CH3通道极性及使能配置
  13. //初始化HALL捕获输入定义器
  14. void Init_TIM2(void)
  15. {
  16.         //计数器禁止、ARR预装载禁止、向上计数、边沿对齐模式
  17.         TIM2->CR1 = BIT2;
  18.         //禁止TIM2所有中断
  19.         TIM2->IER = 0;//禁止中断
  20.         TIM2->CCMR1 = 0x01;//TIM2的CH1\CH2\CH3通道配置为输入
  21.         TIM2->CCMR2 = 0x01;
  22.         TIM2->CCMR3 = 0x01;
  23.         #define IC_FILTER (u8)(5 << 4)
  24.         TIM2->CCMR1 |= IC_FILTER; //输入捕获滤波器
  25.         TIM2->CCMR2 |= IC_FILTER;
  26.         TIM2->CCMR3 |= IC_FILTER;
  27.         //prescale = div3 @ 16MHz -> 0.5us/count * 24MHz -> 0.33us/count
  28.         TIM2->PSCR = 0;
  29.         TIM2->ARRH=0xff;//计数周期设为最大
  30.         TIM2->ARRL=0xff;
  31.
  32.         TIM2->CCER1 |= 0x01;//TIM2的CH1\CH2\CH3通道使能捕获功能
  33.         TIM2->CCER1 |= 0x10;
  34.         TIM2->CCER2 |= 0x01;
  35.         TIM2->CR1 |= 0x01;//使能TIM2定时器
  36. }
  37. //根据HALL状态换相,启动电机运行
  38. void TIM2_InitCapturePolarity(void)
  39.         {
  40.                 u8 bHStatus = 0;
  41.                 GPIOD->DDR &= (u8)(~(0x1c));//HALL端口模式配置
  42.
  43.                 // Read status of H1 and set the expected polarity
  44.         if (H1_PORT & H1_PIN)
  45.         {
  46.                 TIM2->CCER1 |= BIT1;
  47.                 bHStatus |= BIT2;
  48.         }
  49.         else
  50.         {
  51.                 TIM2->CCER1 &= (u8)(~(BIT1));
  52.         }
  53.
  54.         // Read status of H2 and set the expected polarity
  55.         if (H2_PORT & H2_PIN)
  56.         {
  57.                 TIM2->CCER1 |= BIT5;
  58.                 bHStatus |= BIT1;
  59.         }
  60.         else
  61.         {
  62.                 TIM2->CCER1 &= (u8)(~(BIT5));
  63.         }
  64.
  65.                 // Read status of H3 and set the expected polarity
  66.         if (H3_PORT & H3_PIN)
  67.         {
  68.                         TIM2->CCER2 |= BIT1;
  69.                         bHStatus |= BIT0;
  70.         }
  71.         else
  72.         {
  73.                         TIM2->CCER2 &= (u8)(~(BIT1));
  74.         }
  75.                 bHallStartStep = bHallSteps[0][bHStatus];//得到换相步序
  76.                 if (bHallStartStep == 7)//不该出现的HALL状态
  77.                 {
  78.                         return;
  79.                 }
  80.
  81.                 TIM2->SR1=(u8)~(TIM2_IT_CC3|TIM2_IT_CC2|TIM2_IT_CC1);
  82.                 TIM2->IER = 0x0e;//使能输入捕获中断
  83.                 ComHandler();//输出PWM信号,启动电机
  84. }
  85. //捕获中断,即HALL状态变化时,进入此中断
  86. @near @interrupt @svlreg void TIM2_CAP_COM_IRQHandler(void)
  87. {
  88.         u8 bHStatus = 0;
  89.         // Read status of H1 and set the expected polarity
  90.         if (H1_PORT & H1_PIN)
  91.         {
  92.                 TIM2->CCER1 |= BIT1;
  93.                 bHStatus |= BIT2;
  94.         }
  95.         else
  96.         {
  97.                 TIM2->CCER1 &= (u8)(~(BIT1));
  98.         }
  99.
  100.         // Read status of H2 and set the expected polarity
  101.         if (H2_PORT & H2_PIN)
  102.         {
  103.                 TIM2->CCER1 |= BIT5;
  104.                 bHStatus |= BIT1;
  105.         }
  106.         else
  107.         {
  108.                 TIM2->CCER1 &= (u8)(~(BIT5));
  109.         }
  110.
  111.         // Read status of H3 and set the expected polarity
  112.         if (H3_PORT & H3_PIN)
  113.         {
  114.                 TIM2->CCER2 |= BIT1;
  115.                 bHStatus |= BIT0;
  116.         }
  117.         else
  118.         {
  119.                 TIM2->CCER2 &= (u8)(~(BIT1));
  120.         }
  121.
  122.         if (TIM2->SR1 & BIT2)
  123.         {
  124.                 TIM2->SR1=(u8)(~TIM2_IT_CC2);
  125.         }
  126.         if (TIM2->SR1 & BIT1)
  127.         {
  128.                 TIM2->SR1=(u8)(~TIM2_IT_CC1);
  129.         }
  130.         if (TIM2->SR1 & BIT3)
  131.         {
  132.                 TIM2->SR1=(u8)(~TIM2_IT_CC3);
  133.         }
  134.         bHallStartStep = bHallSteps[0][bHStatus];//得到换相步序
  135.         if (bHallStartStep == 7)
  136.         { //故障,停止输出
  137.                 TIM1->BKR &= (uint8_t)(~TIM1_BKR_MOE);//禁止PWM输出
  138.                 PWM_A_OFF;
  139.                 PWM_B_OFF;
  140.                 PWM_C_OFF;
  141.                 return;
  142.         }
  143.
  144.         ComHandler();        //换相
  145.         return;
  146. }
  147. //换相子函数
  148. void         ComHandler(void)
  149. {
  150.         TIM1->BKR &= (uint8_t)(~TIM1_BKR_MOE);//禁止PWM输出
  151.         if(bHallStartStep!=3&&bHallStartStep!=4)
  152.         PWM_A_OFF;
  153.         if(bHallStartStep!=0&&bHallStartStep!=5)
  154.         PWM_B_OFF;
  155.         if(bHallStartStep!=1&&bHallStartStep!=2)
  156.         PWM_C_OFF;
  157.
  158.         //根据换相步序,打开不同的开关管,并施加正确的PWM信号
  159.         if(bHallStartStep==0)//AB
  160.         {
  161.                 TIM1->CCR1H = (uint8_t)(OutPwmValue >> 8);
  162.     TIM1->CCR1L = (uint8_t)(OutPwmValue);
  163.                 PWM_B_ON;
  164.         }
  165.   else if(bHallStartStep==1)        //AC
  166.         {
  167.                 TIM1->CCR1H = (uint8_t)(OutPwmValue >> 8);
  168.     TIM1->CCR1L = (uint8_t)(OutPwmValue);
  169.           PWM_C_ON;
  170.         }
  171.         else if(bHallStartStep==2)        //BC
  172.         {
  173.                 TIM1->CCR2H = (uint8_t)(OutPwmValue >> 8);
  174.     TIM1->CCR2L = (uint8_t)(OutPwmValue);
  175.           PWM_C_ON;
  176.         }
  177.         else if(bHallStartStep==3)        //BA
  178.         {
  179.                 TIM1->CCR2H = (uint8_t)(OutPwmValue >> 8);
  180.     TIM1->CCR2L = (uint8_t)(OutPwmValue);
  181.           PWM_A_ON;
  182.         }
  183.         else if(bHallStartStep==4)//CA
  184.         {
  185.                 TIM1->CCR3H = (uint8_t)(OutPwmValue >> 8);
  186.     TIM1->CCR3L = (uint8_t)(OutPwmValue);
  187.           PWM_A_ON;
  188.         }
  189.         else if(bHallStartStep==5)        //CB
  190.         {
  191.                 TIM1->CCR3H = (uint8_t)(OutPwmValue >> 8);
  192.     TIM1->CCR3L = (uint8_t)(OutPwmValue);
  193.           PWM_B_ON;
  194.         }
  195.
  196.         TIM1->CCER1=PWM_EN1_TAB[bHallStartStep];
  197.         TIM1->CCER2=PWM_EN2_TAB[bHallStartStep];
  198.         TIM1->BKR|=TIM1_BKR_MOE;//使能PWM输出
  199. }
这一段是用tim2定时器捕获的霍尔信号模块,可以正常运行,然而我用外部中断,却不可以正常工作
12
